Luke 42287 Posted December 23, 2021 Posted December 23, 2021 On 12/18/2021 at 4:18 AM, sonusfaber said: Well... after tested several setup (Emby Android TV, Emby std, Kodi, Plex, with movies and music only files...), I have the proof that the audio is very very low only when watching movies with Emby while listening to music with Emby is perfect. How can I understand that it happens only during transcoding? Thanks EDIT: installed Emby on my Android Sony phone: same thing... audio very very low compared to Kodi. It means that even setting the volume to the maximum allowed, it is still lot enough Can we please look at an example from the Emby android app? The example you provided is from the Chrome browser. Thanks.
sonusfaber 17 Posted December 27, 2021 Author Posted December 27, 2021 Do you mean I need to post the Emby log when I play the movie from Android?
Luke 42287 Posted December 27, 2021 Posted December 27, 2021 1 hour ago, sonusfaber said: Do you mean I need to post the Emby log when I play the movie from Android? That would be great, thanks.
sonusfaber 17 Posted December 28, 2021 Author Posted December 28, 2021 Here is the log Just removed the URL where I stream from Azure ffmpeg-remux-310a1c5c-4799-4519-a16f-a0d1045d7380_1.txt P.S.: I tested the setup on Ubuntu on Azure... the audio is the same... very low. It seems that the audio il low only when the emby server transcode.
rbjtech 5345 Posted December 28, 2021 Posted December 28, 2021 (edited) So this is transcoding DTS to AC3 - the ffmpeg configuration doing this is below -c:a:0 ac3 -ab:a:0 384000 -ar:a:0 48000 -ac:a:0 6 If you have the 'Diagnostic Options' plugin loaded - then you can substitute parameters in the actual ffmpeg command line to try and solve the issue. in the 'Parameter Adjustment' section - copy the above into 'Text to Replace' in the Replacement text use :- -c:a:0 ac3 -ac:a:0 2 This tells ffmpeg to use AC3 but remux to Stereo only and use the default AC3 bitrate and sampling frequency. This will actually work for ALL files that are being transcoded (DTS > AC3) not just this example. If this plays at the correct level - then we know it's something to do with the ffmpeg conversion - likely the mapping of the channels if the Stereo version works ok. Edited December 28, 2021 by rbjtech
sonusfaber 17 Posted December 29, 2021 Author Posted December 29, 2021 will have a look ASAP. I am currently travelling. 1
sonusfaber 17 Posted January 9, 2022 Author Posted January 9, 2022 OK. Back from winter holiday yesterday. Unfortunately I am not able to install the plugin. it says "installation failed" and, after that, Emby was no more running correctly, refusing me to connect. xxxxxxx@xxxxx:~$ sudo service emby-server status ● emby-server.service - Emby Server is a personal media server with apps on just about every device Loaded: loaded (/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: failed (Result: core-dump) since Sun 2022-01-09 23:25:38 UTC; 48min left Process: 813 ExecStart=/opt/emby-server/bin/emby-server (code=dumped, signal=ABRT) Main PID: 813 (code=dumped, signal=ABRT) Jan 09 23:25:38 ubuntu-emby emby-server[813]: Unhandled exception. System.IO.IOException: No space left on device Jan 09 23:25:38 ubuntu-emby emby-server[813]: at System.IO.FileStream.WriteNative(ReadOnlySpan`1 source) Jan 09 23:25:38 ubuntu-emby emby-server[813]: at System.IO.FileStream.FlushWriteBuffer() Jan 09 23:25:38 ubuntu-emby emby-server[813]: at System.IO.FileStream.FlushInternalBuffer() Jan 09 23:25:38 ubuntu-emby emby-server[813]: at System.IO.FileStream.Flush(Boolean flushToDisk) Jan 09 23:25:38 ubuntu-emby emby-server[813]: at Emby.Server.Implementations.Logging.FileLogger.Dispose() Jan 09 23:25:38 ubuntu-emby emby-server[813]: at Emby.Server.Implementations.Logging.SimpleLogManager.Dispose() Jan 09 23:25:38 ubuntu-emby emby-server[813]: at EmbyServer.Program.Main(String[] args) Jan 09 23:25:38 ubuntu-emby systemd[1]: emby-server.service: Main process exited, code=dumped, status=6/ABRT Jan 09 23:25:38 ubuntu-emby systemd[1]: emby-server.service: Failed with result 'core-dump'.
Happy2Play 9814 Posted January 9, 2022 Posted January 9, 2022 14 minutes ago, sonusfaber said: Unhandled exception. System.IO.IOException: No space left on device This somewhat says it all. Wild guess would be a full transcode-temp folder. But really has nothing to do with this existing topic.
sonusfaber 17 Posted January 9, 2022 Author Posted January 9, 2022 (edited) I know... How can I investigate this issue, since the used space is only 23% of the total ? This Ubuntu setup was running fine since lot of days, without any failure. I just selected the plugin, hit install and... failed. Now Emby does not start anymore. Edited January 9, 2022 by sonusfaber
Happy2Play 9814 Posted January 9, 2022 Posted January 9, 2022 9 minutes ago, sonusfaber said: I know... How can I investigate this issue, since the used space is only 23% of the total ? This Ubuntu setup was running fine since lot of days, without any failure. I just selected the plugin, hit install and... failed. Now Emby does not start anymore. Is there content in this folder? /var/lib/emby/transcoding-temp If so if you empty that folder does Emby start?
sonusfaber 17 Posted January 10, 2022 Author Posted January 10, 2022 yes, I deleted everything and now it runs again I made a mistake during setup... I need more space. What is the suggested disk size for Emby on Ubuntu?
rbjtech 5345 Posted January 10, 2022 Posted January 10, 2022 (edited) 25 minutes ago, sonusfaber said: What is the suggested disk size for Emby on Ubuntu? Impossible to say. Keep the metadata with the media, then I'd say 10-20Gb for a large collection (30k episodes/films) - make sure you set the metadata setting during the library setup or you may run into this issue again. Edited January 10, 2022 by rbjtech
Happy2Play 9814 Posted January 10, 2022 Posted January 10, 2022 1 hour ago, sonusfaber said: yes, I deleted everything and now it runs again I made a mistake during setup... I need more space. What is the suggested disk size for Emby on Ubuntu? Sorry what does deleted everything mean? But everyone's setup, collection of media and setting are different, so it is impossible to say on required disk space. But remember all transcoding will pretty much require the original files size in space, but assuming everything is done correctly Emby should delete that session upon playback stop. If the session is not cleaned up you will have to manually clear out the transcode-temp folder or Restarting Emby should clear the folder also.
sonusfaber 17 Posted January 10, 2022 Author Posted January 10, 2022 12 hours ago, Happy2Play said: Sorry what does deleted everything mean? i deleted all the content of the transcoding-temp folder, then Emby was able to restart again. Emby should anyway delete these files when starting, or not? Anyway... then I deleted the virtual machine and rebuilt the server from scratch with more space. It was my fault, because yes... the disk was large enough ( 64 GB ) but Ubuntu setup automatically configured the LVM with less space than the available and I did not put my attention on it. Sorry.
Luke 42287 Posted January 10, 2022 Posted January 10, 2022 3 hours ago, sonusfaber said: i deleted all the content of the transcoding-temp folder, then Emby was able to restart again. Emby should anyway delete these files when starting, or not? It does on server startup as well as when transcoding jobs end.
sonusfaber 17 Posted January 12, 2022 Author Posted January 12, 2022 On 12/29/2021 at 7:31 PM, Luke said: @sonusfaber ? On 12/28/2021 at 1:50 PM, rbjtech said: If you have the 'Diagnostic Options' plugin loaded - then you can substitute parameters OK, I performed the test. Sorry but I was travelling during my winter vacation... No improvement at all... the audio level still remains the same BUT.... in the transcoding option there is the opportunity to tell to ffmepg to boost audio when downmixing, from 0.5 to 3.0. Even at 3.0 the level is still too low compared to Kodi or other programs. If it put anything more than 3.0 then it is reverted to 3.0 So I went to the emby config on the linux filesystem and forced a value larger than 3.0... no result... seems that it is oveeride So... i put in the text to replace "volume=3" and to be replaced with "volume=6" and it works!!!!! Luke... why one can not put anything bigger than 3.0 in the audio boost? Let us to use the value we prefer. Why not?
Luke 42287 Posted January 12, 2022 Posted January 12, 2022 Yea I guess we can look at allowing higher values. Thanks for the update. 1
rbjtech 5345 Posted January 12, 2022 Posted January 12, 2022 @sonusfaber Did you ever try what I suggested back in Dec ? (see below) Also - If you can provide the log of the Audio transcode with the Audio Boost, you should be able to update the boost number used in the ffmpeg filter by using the text substitution using the same method. On 28/12/2021 at 12:50, rbjtech said: So this is transcoding DTS to AC3 - the ffmpeg configuration doing this is below -c:a:0 ac3 -ab:a:0 384000 -ar:a:0 48000 -ac:a:0 6 If you have the 'Diagnostic Options' plugin loaded - then you can substitute parameters in the actual ffmpeg command line to try and solve the issue. in the 'Parameter Adjustment' section - copy the above into 'Text to Replace' in the Replacement text use :- -c:a:0 ac3 -ac:a:0 2 This tells ffmpeg to use AC3 but remux to Stereo only and use the default AC3 bitrate and sampling frequency. This will actually work for ALL files that are being transcoded (DTS > AC3) not just this example. If this plays at the correct level - then we know it's something to do with the ffmpeg conversion - likely the mapping of the channels if the Stereo version works ok.
sonusfaber 17 Posted January 13, 2022 Author Posted January 13, 2022 10 hours ago, rbjtech said: Did you ever try what I suggested back in Dec ? (see below) Yes... if you go back two messages... I did the test yesterday, since I was away for vacation and I would like to make the test at home in the same conditions as before. 10 hours ago, rbjtech said: you should be able to update the boost number used in the ffmpeg filter by using the text substitution using the same method. Yes I also did this test... 1) the transcode default accepts only values from 0.5 to 3.0. Inserting anything bigger than 3.0 will not be accepted 2) I modified the config directly on the filesystem bypassing the web interface ( /var/lib/emby/config) replacing 3.0 with something bigger... no improvements, since it seems to be reverted to 3.0 3) finally I used the text replacement: "volume=3" replaced with"volume=6" and it is perfect. it works
SJAnderson 0 Posted January 25, 2022 Posted January 25, 2022 (edited) On 1/13/2022 at 4:32 AM, sonusfaber said: Yes... if you go back two messages... I did the test yesterday, since I was away for vacation and I would like to make the test at home in the same conditions as before. Yes I also did this test... 1) the transcode default accepts only values from 0.5 to 3.0. Inserting anything bigger than 3.0 will not be accepted 2) I modified the config directly on the filesystem bypassing the web interface ( /var/lib/emby/config) replacing 3.0 with something bigger... no improvements, since it seems to be reverted to 3.0 3) finally I used the text replacement: "volume=3" replaced with"volume=6" and it is perfect. it works Having the same issue. Brand new user and need some guidance / help on where exactly and how one accomplishes the text replacement: "volume=3" replaced with"volume=6" referenced above. Running on Qnap NAS running QTS. Edited January 25, 2022 by SJAnderson
Happy2Play 9814 Posted January 25, 2022 Posted January 25, 2022 19 minutes ago, SJAnderson said: Having the same issue. Brand new user and need some guidance / help on where exactly and how one accomplishes the text replacement: "volume=3" replaced with"volume=6" referenced above. Running on Qnap NAS running QTS. The method is with the Diagnostics Plugin in the Parameter Adjustment section. Those options are intended to help investigating problems and should only be set when requested by Emby staff. None of those are intended to fix a problem for regular Emby operation. Settings made here will not be saved. They won't survive a server restart and might be automatically reset after some time.
SJAnderson 0 Posted January 25, 2022 Posted January 25, 2022 32 minutes ago, Happy2Play said: The method is with the Diagnostics Plugin in the Parameter Adjustment section. Those options are intended to help investigating problems and should only be set when requested by Emby staff. None of those are intended to fix a problem for regular Emby operation. Settings made here will not be saved. They won't survive a server restart and might be automatically reset after some time. Thanks - confirming the parameter change will revert to default setting following server restart. Seems like a good place to experiment.
elche27 3 Posted June 22, 2022 Posted June 22, 2022 Hello to all!! Having the same issue. Brand new user and need some guidance / help on where exactly and how one accomplishes the text replacement: "volume=3" replaced with"volume=6" referenced above?? Best Regards!!
Happy2Play 9814 Posted June 22, 2022 Posted June 22, 2022 21 minutes ago, elche27 said: Hello to all!! Having the same issue. Brand new user and need some guidance / help on where exactly and how one accomplishes the text replacement: "volume=3" replaced with"volume=6" referenced above?? Best Regards!! This is an option in the Diagnostics plugin found in the catalog. Note these options are for testing.
