usenet 1 Posted December 8, 2021 Posted December 8, 2021 (edited) Hi I got a Logitech Bluetooth K830 keyboard connected to my Samsung TV I can use keyboard to navigates but if I search and use the keyboard to type in search phrase it wont work, have to used the pop up alphabet with the remotes is this a bug or feature not supported? Edited December 8, 2021 by usenet
Luke 42241 Posted December 8, 2021 Posted December 8, 2021 Hi, are you able to enter characters in other places, such as the login screen?
usenet 1 Posted December 8, 2021 Author Posted December 8, 2021 yes I can use the keyboard input to type my password at the login screen, only search text input doesn't work, have to navigate the pop up alphabet
Luke 42241 Posted December 8, 2021 Posted December 8, 2021 Right OK. There isn't actually a text input on the search screen, so that is the reason for that.
usenet 1 Posted December 8, 2021 Author Posted December 8, 2021 11 minutes ago, Luke said: Right OK. There isn't actually a text input on the search screen, so that is the reason for that. Is there plan for an update to that function or that the way it is?
usenet 1 Posted December 8, 2021 Author Posted December 8, 2021 Thanks I am a plex pass user but I like Emby media layout and config more so I am evaluating all the options I am using in Plex to see if Emby does it better, so far that search function keyboard input is a show stopper for me, get it working and I will sign up premiere life time 1
SamES 1084 Posted December 9, 2021 Posted December 9, 2021 One of the issues here is that if we allow keyboard entry it also means that the standard Samsung on-screen keyboard will also appear, then Samsung will raise a defect as we have two onscreen keyboard methods We would just need to decide how this would be best supported
usenet 1 Posted December 9, 2021 Author Posted December 9, 2021 (edited) 26 minutes ago, SamES said: One of the issues here is that if we allow keyboard entry it also means that the standard Samsung on-screen keyboard will also appear, then Samsung will raise a defect as we have two onscreen keyboard methods We would just need to decide how this would be best supported works with plex no problem on Samsung TV, the keyboard alphabet map would appear but I can still type and search in their search box so I don't see a problem with you prompting for keyboard alphabet map like Plex and still let user type in the input box just to clarified on this point, I can still use the TV remote and select individual characters on the keyboard map or I can just go to the search box and start typing away in Plex and they both work Edited December 9, 2021 by usenet
SamES 1084 Posted December 9, 2021 Posted December 9, 2021 The issue is that we have our own letter picker below the search box. If we also show the on-screen keyboard then Samsung will complain about having both. The other option is to remove our letter picker and just use the native on screen keyboard (which is probably my preference) but Luke will have to make this decision.
usenet 1 Posted December 9, 2021 Author Posted December 9, 2021 Ok I see what you mean about duplicate keyboards as Emby has its own green keyboard row and Samsung square box keyboard map This search is particular useful for a certain setup and certainly in my case as I use Plex/Emby to setup Karaoke server for my wife, she is into Karaoke and she use search function dozen or more time each session with her friends and it unworkable manually navigates the alphabet with the remote it basically ruined the experience having to spend a minute or two navigates the keyboard map to type in the text you want I made collections and playlist but still if it get large search is a lot faster if you can type
Luke 42241 Posted December 9, 2021 Posted December 9, 2021 That's right I forgot about this. Samsung actually rejected our submission back when we had it enabled.
usenet 1 Posted December 9, 2021 Author Posted December 9, 2021 (edited) for what it worth, I am installing the app via USB as I am outside the smarthub zone so if you need it test let me know I also blocked all the smarthub stuff from my TV as it is too chatty and send too much stuff back to Samsung servers I only enable it if I need to install an app from it then it goes back on block list Edited December 9, 2021 by usenet
SamES 1084 Posted December 9, 2021 Posted December 9, 2021 (edited) 1 hour ago, Luke said: That's right I forgot about this. Samsung actually rejected our submission back when we had it enabled. Correct. If you're happy to drop the alpha row, we can easily enable the Samsung keyboard which will also enable the external keyboard (and remote control apps that enable entering test screens on the phone then sending them to the app). @usenet, I expect you experience this same issue with Netflix, youtube and all the other major apps that also use their own on-screen keyboard entry methods. Correct? Edited December 9, 2021 by SamES
usenet 1 Posted December 9, 2021 Author Posted December 9, 2021 (edited) 48 minutes ago, SamES said: Correct. If you're happy to drop the alpha row, we can easily enable the Samsung keyboard which will also enable the external keyboard (and remote control apps that enable entering test screens on the phone then sending them to the app). @usenet, I expect you experience this same issue with Netflix, youtube and all the other major apps that also use their own on-screen keyboard entry methods. Correct? @SamES I just test youtube and nextflix I don't have the issue, Samsung keyboard popup and I can still search using keyboard to type, exact same experience with Plex so these vendors implement Samsang Keyboard map in similar fashion Happy to Test out the Alpha and if it works I will sign up premiere as promise Edited December 9, 2021 by usenet
TOMinSATX 0 Posted December 23, 2021 Posted December 23, 2021 Just to stick my nose in here... I just got a Riitek i4 wireless/bluetooth keyboard to use on my 2019 Samsung QN75Q70RA and it seems to work fine so far, until I tried it on EMBY. Using the keyboard on the Samsung Internet feature presents no problems, as the Samsung keyboard doesn't even show up (as long as I turn on the Bluetooth Keyboard). On EMBY it works in general functions such as moving around the screen, selecting movies, scrolling, and even using the touchpad to type using the EMBY keyboard for searching, but not for actually typing in the search. Seems like since I have a choice to show the keyboard on the EMBY screen, not showing it should allow me to type in my search. I'm a retired programmer (2003=Dinosaur), so I understand that you don't actually have a field for search entry, but if you could have that and not allow the Samsung to bring up its keyboard it sure would be nice.
TOMinSATX 0 Posted December 23, 2021 Posted December 23, 2021 Thanks for the quick reply. I look forward to the new release.
SamES 1084 Posted February 13, 2022 Posted February 13, 2022 Have you tried this in the latest USB release?
