Luke 42239 Posted December 8, 2021 Posted December 8, 2021 Hi there, what exactly do you need help with)
Johnny588 0 Posted December 8, 2021 Author Posted December 8, 2021 Everytime I go log in it tells me unable to connect
gillmacca01 220 Posted December 8, 2021 Posted December 8, 2021 Have you installed the server software?
Johnny588 0 Posted December 8, 2021 Author Posted December 8, 2021 The server is called localhost, but will not connect.
Johnny588 0 Posted December 8, 2021 Author Posted December 8, 2021 32 minutes ago, Luke said: Hi Spoiler there, what exactly do you need help with) 33 minutes ago, Luke said: Hi there, what exactly do you need help with) Spoiler
Luke 42239 Posted December 8, 2021 Posted December 8, 2021 Are you trying to connect to your own Emby Server, or someone else's?
Luke 42239 Posted December 8, 2021 Posted December 8, 2021 1 minute ago, Johnny588 said: My own, I do believe What device did you install Emby Server on? What version is it?
Johnny588 0 Posted December 8, 2021 Author Posted December 8, 2021 4 minutes ago, Luke said: What device did you install Emby Server on? What version is it? My android cell phone.
seanbuff 1356 Posted December 9, 2021 Posted December 9, 2021 10 hours ago, Johnny588 said: My android cell phone. Have you followed the Quick Start Guide? https://support.emby.media/support/solutions/articles/44001159034-quick-start I suggest you take a look at that, and let us know where you get stuck.
EODCrafter 181 Posted December 13, 2021 Posted December 13, 2021 On 12/8/2021 at 4:11 PM, Johnny588 said: My android cell phone. Follow the guide above, looks like your confusing Server with Client App. I don't think anyone would recommend Emby Server on a Cellphone.
