SALKLABIB 0 Posted December 5, 2021 Posted December 5, 2021 j'arrive Pas a installer emby sur mon qnap ts-453 BT3. erreur emby instal.zip
Luke 42239 Posted December 6, 2021 Posted December 6, 2021 @SALKLABIB Hi there, what exactly happened when you tried to install?
Luke 42239 Posted December 8, 2021 Posted December 8, 2021 What version of QTS do you have installed?
Luke 42239 Posted December 30, 2021 Posted December 30, 2021 @SALKLABIB is that the latest version of QTS available for your QNAP?
Luke 42239 Posted December 31, 2021 Posted December 31, 2021 OK I've assigned this to our package developer for review. Thanks.
alucryd 318 Posted January 2, 2022 Posted January 2, 2022 Bonjour, pouvez-vous vérifier le hash du package que vous essayez d'installer ? Exemple sous windows: https://lecrabeinfo.net/verifier-integrite-calculer-empreinte-checksum-md5-sha1-sha256-fichier-windows.html#avec-powershell-et-get-filehash La valeur devrait être : 41ecb573cde31acfb483a88bbe6bd3ac6e1d672aa2df9c53fad4f5317f5eefec
SALKLABIB 0 Posted January 6, 2022 Author Posted January 6, 2022 Sorry i just find it (SHA-256) it the same as the example.
SALKLABIB 0 Posted January 16, 2022 Author Posted January 16, 2022 i still have the same problème. what should i do.
