Satanasss 11 Posted December 15, 2021 Posted December 15, 2021 (edited) ... Edited December 15, 2021 by Satanasss
Satanasss 11 Posted December 15, 2021 Posted December 15, 2021 20 minutes ago, ebr said: Hi. What is your "Login behavior" set to? So from memory: I launch the Emby Android TV application and I go directly to the media library (when the PC is on). (If the PC is on standby, then follow what is said above: wait, then send the WAKE manually). Basically, this automatically connects without having to enter a USER or MDP. Exactly, yesterday I even tried by modifying the parameters by: always automatically connect to this server etc. Same, no WOL sent automatically.
ebr 16337 Posted December 15, 2021 Posted December 15, 2021 Okay, I think I've found why it isn't sending. You can retest with next beta. Thanks. 1
Satanasss 11 Posted December 16, 2021 Posted December 16, 2021 Salvation, I'll try the beta when it's available. Thank you
Satanasss 11 Posted December 19, 2021 Posted December 19, 2021 (edited) Tested "V.2.0.60" on Shield TV and Fire TV Edited December 19, 2021 by Satanasss 1
ebr 16337 Posted December 19, 2021 Posted December 19, 2021 3 hours ago, Satanasss said: However, the player takes a long time to load the videos and during playback it generates pauses. That would be something completely unrelated. Please start a new thread and attach the information requested in how to report a media playback issue. Thanks!
edzz83 4 Posted September 5, 2022 Posted September 5, 2022 Hi Emby Team, Quick question here, is this WOL Feature (automatically firing WOL packet on launch of app) been implemented across the Xbox App + LGTV WebOS app? Would love to know if its added to those apps as well as my media server really needs some sleep
Luke 42245 Posted September 5, 2022 Posted September 5, 2022 58 minutes ago, edzz83 said: Hi Emby Team, Quick question here, is this WOL Feature (automatically firing WOL packet on launch of app) been implemented across the Xbox App + LGTV WebOS app? Would love to know if its added to those apps as well as my media server really needs some sleep Hi, Xbox yes but it's not possible on LG.
edzz83 4 Posted September 5, 2022 Posted September 5, 2022 Any idea if there is a way to make WOL work on a local setup? Both the Media Server + LG WebOS app are local on LAN using ethernet, perhaps using port triggering or something locally?
Luke 42245 Posted September 5, 2022 Posted September 5, 2022 12 hours ago, edzz83 said: Any idea if there is a way to make WOL work on a local setup? Both the Media Server + LG WebOS app are local on LAN using ethernet, perhaps using port triggering or something locally? LG doesn't provide any kind of socket api for developers to work with. That's what would be needed in order to do this.
