FrogMaster 27 Posted January 14, 2022 Author Posted January 14, 2022 Upgraded from 4.7.0.18 to 4.7.0.20 without any issues. I believe this has been rectified.
quietday 2 Posted January 14, 2022 Posted January 14, 2022 4.7.0.20 upgraded without the need to manually manage versions of Mono and Tesseract. I did have to reinstall ffmpeg, which was somehow removed during the upgrade from 0.19. A separate issue, navigating between rows on an LG TV with the latest app does not scroll following the selection. The selection can go off-screen, requiring you to toggle up and down to "wiggle" it into view.
FrogMaster 27 Posted January 14, 2022 Author Posted January 14, 2022 5 hours ago, quietday said: 4.7.0.20 upgraded without the need to manually manage versions of Mono and Tesseract. I did have to reinstall ffmpeg, which was somehow removed during the upgrade from 0.19. A separate issue, navigating between rows on an LG TV with the latest app does not scroll following the selection. The selection can go off-screen, requiring you to toggle up and down to "wiggle" it into view. Fortunately, when I upgraded to .20 I didn't have any issues with FFMPEG. I would suggest you make a new thread for your other issue. You will probably get more visibility and feedback that way, rather then at the bottom of this unrelated thread.
NinthWave 2 Posted January 17, 2022 Posted January 17, 2022 I have got the same problem since I updated. I don't play movies that often so it took me a while to figure it stopped working. At first I suspected ACL but I found this thread. I also get the message about no streams beeing available. So what is the fix ? I am not sure I understand what to do. Thanks
Luke 42237 Posted January 17, 2022 Posted January 17, 2022 1 hour ago, NinthWave said: I have got the same problem since I updated. I don't play movies that often so it took me a while to figure it stopped working. At first I suspected ACL but I found this thread. I also get the message about no streams beeing available. So what is the fix ? I am not sure I understand what to do. Thanks Hi, can you update to the latest version of Emby Server?
