Dan833 7 Posted December 1, 2021 Posted December 1, 2021 Hi, would you be possible to make these expandable, so you can share certain tv shows to different users. Unless there is another way of doing it. I'm pretty new to Emby. It would also be nice to add a shared folder to the library and it honours the folder strcuture on the share drive. Some movie collections cannot be sorted with either Name, Title or Release Date. This is how i have Star Wars set-up for example so Kodi can organise them properly. I am running Emby on a DS218Play running DSM 6.2.4 - 25556 Thanks.
ebr 16339 Posted December 1, 2021 Posted December 1, 2021 Hi. There are a few other ways you can do this. You can use the parental controls and use either ratings or tags.
MBSki 1115 Posted December 1, 2021 Posted December 1, 2021 For sharing, using sub-folders is 1 option if you have a lot to share. I use tags and the parental control filter instead since i only have a handful of movies/tv shows that I want to share. So i just tag what I want to share and use this option in parental controls. For ordering items, what you have is one way to do it, but i don't think Emby or Plex works that way. I tend to use Playlists when I want something ordered exactly in the order that I want to see it. Otherwise I just use the built in air date or title orders.
rbjtech 5345 Posted December 2, 2021 Posted December 2, 2021 (edited) For the Sort order - simply add the 'sorted' name into the 'Sort title' field (via Edit Metadata) On the actual Collection - you then need to tell it to display in the 'Sort' order instead :- I put the 'Star Wars Stories' after the main saga, but you get the idea .. Edited December 2, 2021 by rbjtech
Dan833 7 Posted December 2, 2021 Author Posted December 2, 2021 rbjtech thanks for this, seems an easier way to do it. I can sort Avengers & Conjuring collections as well now 1
