eltioares 9 Posted December 1, 2021 Posted December 1, 2021 Hola tengo un amigo que vive en el cambo y tiene una media de 30 y 15 megas pero se le para la reproduccion bastante por la velocidad de internet estable que tiene, con el netflix y disney le funciona bien pero con el emby no sabeis si hay alguna conf con el cache o alguna cosa para solucionar el problema, eso ya me paso con otro compañero hace tiempo se ve que no se lleva bien emby con los internet de punta a punta. Un saludo.
Carlo 4561 Posted December 9, 2021 Posted December 9, 2021 Hi, Companies like Netflix and Disney prepare multiple versions of each file. It's not uncommon to have over 12 versions of a media stream. What that allows them to do is dynamically change the bitrate of the media being streamed to handle fluctuating media levels. This is actually quite easy to do if you want to have that many versions of media prepared and stored. Emby Server is often times lucky to have the media prepared at all to be in a streaming format and has to deal with all kinds of things that a Netflix would not like hard coded subs, sound tracks in formats that can't be used, resolutions that are to high for the available bandwidth etc.... Without the luxury of having perfectly curated media available to it, Emby server has to deal with what you give it. At present it can not dynamically adjust bandwidth on the fly like this. However you should be able to adjust this on the client side. Each Emby client application allows you to set a maximum bandwidth limit it will use (check playback menu). So if the 15Mb to 30Mb you mentioned was the amount of upload bandwidth available to the Emby server and if we assume you want to be able to handle 2 streams you can calculate 15 / 2 = 7.5 Mb is roughly the limit that should be set to allow 2 clients to play back. You would need to test this as latency and other factors come into play but adjusting each client to something in the 6Mb to 8Mb should make them always use that or less bandwidth which should help fix the problem. It's very important to understand the difference between download and upload bandwidth from the standpoint of the Emby Server. Run a speed test from https://speed.cloudflare.com/ We mostly care about the value given for upload. That is the bandwidth the server has to work with. We want to see the jitter number pretty low as well. Let us know what you get for those two values. Carlo
eltioares 9 Posted December 12, 2021 Author Posted December 12, 2021 Te paso captura de test, va sobrodo solo va a reproducir con un dispotivo a la vez, con el movil le funciona con el 4g pero cuando se conecta a su internet se le para la reproduccion. Por eso creo que es la latencio o ping que es malo en el campo no se si tiene algo que ver pero me gusta siempre aprender cosas nuevas. Y por eso no se si se puede activar algo en la configuracion de emby para solucionarlo. Gracias a todos ^^.
rodainas 191 Posted December 12, 2021 Posted December 12, 2021 De cuanto es la subida desde el equipo que ejecuta el servidor emby?
eltioares 9 Posted December 12, 2021 Author Posted December 12, 2021 Hola, Tengo un 1G simetrico de jazztel sobradisimo solo es con este compañero que vive en el cambio que tengo problemas.
rodainas 191 Posted December 12, 2021 Posted December 12, 2021 (edited) Si el bitrate esta siempre de lo que ha intentado reproducir por debajo de los 50mbit del test, da la impresion que es tema de peering entre los 2 puntos, tal vez la conexion es inestable entre los 2, perdida de paquetes, latencia variable, todo esto complica el tema del buffering. Podrias hacer una prueba de mtr por curiosidad de servidor a cliente y la otra la hace el de cliente a servidor. Edited December 12, 2021 by rodainas Correccion
rodainas 191 Posted December 12, 2021 Posted December 12, 2021 Si ambos usan windows pueden usar por ejemplo https://sourceforge.net/projects/winmtr/
eltioares 9 Posted December 14, 2021 Author Posted December 14, 2021 Nada es el emby que da problemas con las cenetxiones, el netflix y el disney le funcionan bien pero el emby no, y lo unico que veo que el ping que tiene es muy elevado lastima que con el emby de este error seguramente es cosa del cache de carga que se tiene que mejorar o la transcodificacion, da igual dice que no quiere complicarse la vida pasamos del tema. Gracias a todos por la ayuda.
