MMills034 0 Posted December 1, 2021 Posted December 1, 2021 Hi, All remote connections to my server are unavailable after updating to 4.6.7.0 I've tried: -rebooting the Emby server as well as the host machine running the server -removing and re-adding the custom domain -verifying the SSL cert is valid -attempting to access from different client devices The server is still available on the localhost. Also, "localhost" shows as an available server on remote devices. This is something I've never seen before. hen I updated to 4.6.7.0 the update did NOT show as applied until after several server reboots. I kept receiving a message to please restart the server to apply updates/ Could you please assist? Thanks, Mykal I apologize I previously posted under the wrong section (QNAP)
Luke 42197 Posted December 1, 2021 Posted December 1, 2021 Hi there, what exactly happens when you try to connect?
MMills034 0 Posted December 1, 2021 Author Posted December 1, 2021 Hi Luke, When I try to connect, it brings up the server selection screen. If I try to choose a server it returns an error that the server is unavailable. If I try signing in with Emby Connect, it takes me back to the server selection screen. Here are a couple screenshots from my Android.
Luke 42197 Posted December 2, 2021 Posted December 2, 2021 Try doing a manual connection by entering the server address and see if that helps. Thanks.
