Forcesius 0 Posted December 1, 2021 Posted December 1, 2021 Hi. I cannot enter my emby from my phone because it says it needs to update. In packagemanager can i not find a new version of emby. To download manual im not sure which version i shall install to fit my synology. Hope someone can help Model name DS3615xs
Carlo 4561 Posted December 1, 2021 Posted December 1, 2021 Hi, so I went to the download page for Synology 6 on our site: https://emby.media/synology-server.html The first line tells you to Download one of the following packages depending the architecture of your Synology NAS: That is a hyperlink to an architecture link of different models so we open it up. Now to search or find on the page I'll do a CTRL F to bring up the find dialog and enter DS3615xs followed by enter. I get back Which tells me you have an an Intel 64 bit CPU. So back on the main download page you want the first option "64-bit NAS" However, you could also upgrade to 4.6.6 first https://github.com/MediaBrowser/Emby.Releases/releases/download/4.6.6.0/emby-server-synology_4.6.6.0_x86_64.spk Then to 4.6.7 after that. https://github.com/MediaBrowser/Emby.Releases/releases/download/4.6.7.0/emby-server-synology_4.6.7.0_x86_64.spk One this to be careful with if looking at these files directly on github is that there are Synology DSM 6 and DSM 7 versions. There difference between the two is this: emby-server-synology_4.6.7.0_x86_64.spk emby-server-synology7_4.6.7.0_x86_64.spk (this has a 7 right after the y in synology). After getting caught up to current on Emby for DSM 6 have you thought about migrating to DSM 7 yet? BTW, that is a really nice NAS: 12 Bay, ePCIe 3.0 x8 slot, up to 32GB ECC RAM, Intel Core i3-4130 Dual Core 3.4GHz, Gigabit X 4 I like the i3 vs Celeron choice. Intel Core i3-4130 Dual Core 3.4GHz
Forcesius 0 Posted December 1, 2021 Author Posted December 1, 2021 i dont know so much about synology again. Tried to download the package manually down but it writes "Not supported" Perhabs someone could help via teamviewer or another way. To see the problem with your own eyes. Thanx for the praise
Luke 42243 Posted December 1, 2021 Posted December 1, 2021 1 hour ago, Forcesius said: i dont know so much about synology again. Tried to download the package manually down but it writes "Not supported" Perhabs someone could help via teamviewer or another way. To see the problem with your own eyes. Thanx for the praise What did you download?
Forcesius 0 Posted December 1, 2021 Author Posted December 1, 2021 https://github.com/MediaBrowser/Emby.Releases/releases/download/4.6.6.0/emby-server-synology_4.6.6.0_x86_64.spk 64 nas. I have Synology DSM 5. The link below can you see my screen on my synology http://anonym.es/?https://ibb.co/0XC5MB4
Happy2Play 9812 Posted December 1, 2021 Posted December 1, 2021 2 hours ago, Forcesius said: I have Synology DSM 5 Is there a reason you have not updated your DSM? But I believe our packages only support DSM 6 and DSM 7 with each having their own package. Download Center - DS3615xs | Synology Inc. 1
Forcesius 0 Posted December 2, 2021 Author Posted December 2, 2021 Im not sure. A friend told me it was difficult to update. And i dont know so much about it again
Carlo 4561 Posted December 3, 2021 Posted December 3, 2021 I would try to get updated to at least DSM 6. Do you have an active backup of your NAS?
