fredflix 31 Posted December 1, 2021 Posted December 1, 2021 (edited) Up until today I was using 3.0.15-1 from AUR, and it was working great out of the box with default settings. I only found out today that Emby-theater is now in the official repo, so I un-installed 3.0.15-1, and then installed 3.0.15-2 from the official repo. But now, all HDR content only displays a blue screen when played. The sound plays fine however. The nerd stats shows the video is direct playing: Playback Info Play method: DirectPlay Title: Movie.mkv Chapter: 0 Video Info Video codec: hevc (HEVC (High Efficiency Video Coding)) Video bitrate: 16.7 Mbps Video renderer: libmpv Hardware acceleration: vaapi-copy Display sync active: false Dropped frames: 1, Decoder dropped: 0, Mistimed: 0, Delayed: 0 Display Fullscreen Resolution: 2560 x 1440 Video resolution: 3840 x 1600 Aspect ratio: 2.4000000953674316 Pixel format: yuv420p Color matrix: bt.2020-ncl Primaries: bt.2020 Gamma: pq Levels: limited Audio Info Audio codec: truehd Audio channels: 7.1 Audio sample rate: 48000 Audio bitrate: 3.3 Mbps Audio renderer: pulse Original Media Info Container: mkv Bitrate: 38.9 Mbps Video codec: HEVC Main 10 Video bitrate: 38.9 Mbps Video framerate: 23.976025 fps Audio codec: TRUEHD Audio channels: 8 Audio sample rate: 48000 Hz Audio bit depth: 24 Starting from the command line doesn't throw any error either. Searching for this issue suggests switching the video output to "gpu", which I did but still same issue. Matter of fact, I tried all possible combinations of the video output and hardware acceleration mode settings and still a blue screen. Playing HDR videos in the standalone MPV player works fine, so I'm not really sure why it won't work in Emby-Theater. I'm on an Intel i7-8700K cpu with a GTX 1060 gpu, Manjaro Gnome (41.1) if that can help further. Edited December 2, 2021 by fredflix
Luke 42239 Posted December 10, 2021 Posted December 10, 2021 Hi, can you show a screenshot of your video settings in the app? Thanks.
fredflix 31 Posted December 10, 2021 Author Posted December 10, 2021 7 hours ago, Luke said: Hi, can you show a screenshot of your video settings in the app? Thanks. Hey Luke, I just set everything to default for now since trying all the possible combinations doesn't seem to change anything anyway.
fredflix 31 Posted December 10, 2021 Author Posted December 10, 2021 (edited) Here's the standalone MPV on the left and Emby Theater on the right playing side by side at the 26 sec mark, same video file. Non HDR videos regardless of resolution play fine. Edited December 10, 2021 by fredflix
augie754 7 Posted December 19, 2021 Posted December 19, 2021 I'm having the same issue on Manjaro using the same Arch repo. I just tried to rollback to the older AUR version, but it appears that is no longer working. I'll be interested in any updates on this issue.
Luke 42239 Posted December 22, 2021 Posted December 22, 2021 Can you try the auto copy back option for hardware acceleration?
augie754 7 Posted December 23, 2021 Posted December 23, 2021 I just tried Auto copy back, auto and None. All still have the Blue screen on the Linux laptop. My Windows Emby theater is fine using Auto. Here is the process and display info on my Linux laptop. processor Intel(R) Core(TM) i3-1005G1 CPU @ 1.20GHz display Iris Plus Graphics G1 (Ice Lake)
fredflix 31 Posted December 23, 2021 Author Posted December 23, 2021 10 hours ago, Luke said: Can you try the auto copy back option for hardware acceleration? Still blue screen. As I mentioned in the first post. I tried all the combinations possible and I get the blue screen every time =/
mascrugli 1 Posted December 29, 2021 Posted December 29, 2021 (edited) same problem, the problem occurs with HDR content, my display is not HDR so I think the problem is related to tone mapping. mpv is working correctly though, so I don't understand. Edited December 29, 2021 by mascrugli
alucryd 318 Posted January 11, 2022 Posted January 11, 2022 Hi guys, both the AUR package and the official package use different mpv versions, and both are also different from the system mpv. I'll look into our mpv build and see if it might be missing something.
Solution alucryd 318 Posted January 12, 2022 Solution Posted January 12, 2022 Just pushed an updated package in the repos, it should work fine with HDR content now. 1
fredflix 31 Posted January 13, 2022 Author Posted January 13, 2022 20 hours ago, alucryd said: Just pushed an updated package in the repos, it should work fine with HDR content now. I'm on Manjaro. So waiting for them to push your new version. I will report back asap. Thanks for taking care of this :)
fredflix 31 Posted January 26, 2022 Author Posted January 26, 2022 On 1/12/2022 at 2:46 PM, alucryd said: Just pushed an updated package in the repos, it should work fine with HDR content now. Just got the community updates today on Manjaro and your new package indeed does solve the issue! Thanks for taking care of this
pSYoniK 1 Posted January 29, 2022 Posted January 29, 2022 I downloaded the .deb package from downloads page and on Zorin OS (Ubuntu) and Ubuntu Budgie I get a blue screen on my desktop and my laptop on HDR videos. The content works fine when playing straight from the server with VLC. It also worked fine in Windows 10. The desktop has a ryzen 5 2600 with a gtx 1060 card and the laptop is running a ryzen 5600U. PS - before you ask, I did try the GPU renderer and it made no difference.
pSYoniK 1 Posted January 30, 2022 Posted January 30, 2022 I went to the release page on Github and downloaded 3.0.14 deb release and this is working fine. Just curious if more people are having issues with 3.0.15. Thank you for the work on the proj!
Luke 42239 Posted February 18, 2022 Posted February 18, 2022 On 1/30/2022 at 11:06 AM, pSYoniK said: I went to the release page on Github and downloaded 3.0.14 deb release and this is working fine. Just curious if more people are having issues with 3.0.15. Thank you for the work on the proj! @pSYoniK please try downloading the 3.0.15 .deb and see if it is corrected for you now. Thanks.
