vdrover 62 Posted November 30, 2021 Posted November 30, 2021 I have a few channels that are perfect to watch live. But if I try to record, usually get less than a minute of recording. Looking at the logs, it is clearly an issue with the streaming server: Quote 2021-11-30 10:00:26.184 Info SharedHttpPipelineSource: Remote server closed stream https://redacted 2021-11-30 10:00:26.185 Info SharedHttpPipelineSource: Retry opening stream https://redacted 2021-11-30 10:00:26.185 Info SharedHttpPipelineSource: Opening SharedHttpPipelineSource Live stream from https://redacted 2021-11-30 10:00:26.185 Info HttpClient: GET https://redacted 2021-11-30 10:00:26.449 Info HttpClient: Http response 404 from https://redacted after 264ms. HeadersDate=Tue, 30 Nov 2021 16:00:26 GMT, Transfer-Encoding=chunked, Connection=keep-alive, Cache-Control=no-store, must-revalidate, no-cache, Access-Control-Allow-Origin=*, CF-Cache-Status=DYNAMIC, Expect-CT=max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct", Report-To={"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=wsZf1CvHvf%2FTKtEby3adbV%2BgTN33cmjHCADF1uSfLEtS7PPWGqfLq36Rp%2FNz06DhxCjhWDydIBXOl%2BTF2e9FeVcBMuOCUPdPnessV6ZZzuxV9vv0AfPRL6XxD8sfbdUKqGnr"}],"group":"cf-nel","max_age":604800}, NEL={"success_fraction":0,"report_to":"cf-nel","max_age":604800}, Server=cloudflare, CF-RAY=6b6549e3b8a162bd-ORD, Alt-Svc=h3=":443"; ma=86400, h3-29=":443"; ma=86400, h3-28=":443"; ma=86400, h3-27=":443"; ma=86400 2021-11-30 10:00:26.452 Error SharedHttpPipelineSource: Give up retries copying live stream https://redacted What I don't understand is why this happens only when recording. If I watch this channel, there may be an occasional hiccup, but the playback continues. I noticed the logs show `cache-Control=no-store, must-revalidate, no-cache` and wondered if caching might be part of the problem.
Luke 42243 Posted December 1, 2021 Posted December 1, 2021 Hi there, can we please look at an example? Please attach the information requested in how to report a problem. thanks !
vdrover 62 Posted December 1, 2021 Author Posted December 1, 2021 Do you mean to post more of the logs? Or examples of the channels?
Luke 42243 Posted December 1, 2021 Posted December 1, 2021 10 hours ago, vdrover said: Do you mean to post more of the logs? Or examples of the channels? Yes log files please. Thanks.
BillOatman 597 Posted December 1, 2021 Posted December 1, 2021 This used to happen for me all the time. I so rarely record anything though it wasn't a big deal. But recently I started developing a plugin that works on recordings, and I have recorded several 30 minute shows recently and they all worked perfectly. What I do is watch the stream a little bit before the recording starts and make sure the stream itself is reliable. If it is buffering etc. I pull the plug on the recording. For recording like everything else, garbage in ==> garbage out.
vdrover 62 Posted December 1, 2021 Author Posted December 1, 2021 (edited) Here is everything from the start of the recording to the end. 2021-11-30 10:00:00.000 Info LiveTV: Recording timer fired for Heartland. 2021-11-30 10:00:00.006 Info HttpClient: GET https://www.thetvdb.com/api/GetSeriesByRemoteID.php?zap2it=EP00959462&language=en 2021-11-30 10:00:00.166 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/82701/all/en.zip 2021-11-30 10:00:00.296 Info App: MovieDbProvider: Finding id for item: Heartland 2021-11-30 10:00:00.296 Info HttpClient: GET https://api.themoviedb.org/3/search/tv?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Heartland&language=en 2021-11-30 10:00:00.484 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&s=Heartland&type=series 2021-11-30 10:00:00.746 Info LiveTV: Getting media sources for recording from channel 47867 47867 2021-11-30 10:00:00.746 Info LiveTV: Opening live stream for recording from channel 47867 47867 2021-11-30 10:00:00.746 Info LiveTvManager: Opening channel stream from Emby, external channel Id: m3u_0d8acf21a96eaa5ea45ae08216e713c84ee12caa32d058932fc29a3e7f3dde4f 2021-11-30 10:00:00.746 Info LiveTV: Streaming Channel m3u_0d8acf21a96eaa5ea45ae08216e713c84ee12caa32d058932fc29a3e7f3dde4f 2021-11-30 10:00:00.746 Info SharedHttpPipelineSource: Opening SharedHttpPipelineSource Live stream from https://redacted.com/202redacted/redacted/redacted 2021-11-30 10:00:00.746 Info HttpClient: GET https://redacted.com/202redacted/redacted/redacted 2021-11-30 10:00:01.115 Info HttpClient: GET http://balance.redacted.com/auth/y-kKLYo9Jli31GgypLN5vW_7GyscChSJaEGU_c4buZFo19UEQjrwF0lh0YcZp0wa3nvE6m2f5xNJh0mqwSE_MpFsxm21sUYgQCc2W4FYU4ZYAFnftTd8UyRRazXJ7yzKJpiwqsAmwq9Q5Dx1_2YKP9VzI5sg0X3jYivLQaHTTuMscYKqsO2zoHjV87F3-DTjCk1cb7rFUy9MrBhM96gm3DYSATKQm8wRJbQHUSe6yR5rlSH5MI7xvHW6ARLof7krRJF6ISXoKDBezsEP-P3WbJ0K5xCDunJUQsouim9h8to5l0_hAP9Wc1bm6l24l-fxpZIwyVNUZpHAL1K_FLGgxaRQOCdXqajbslzAwGTR15ZtD-J4lKilmGgeKPXPH_bcgLoi7jL00dLUXqj5HuU_PmnuMqW5edeHLzNnPXRo1ag8-S_obXxkG1Kxxuh3QmyN56iz58SSh2MpFgpKNCFxp9DtVnwzgEtCEAC11sbcmoVpg8bMGAwPaQMiyiz7lOpbaoJjVFrqoaBF8wJ1ooyQit8CsEorZopGec8_9AwycHL_szPIIOsOEhdy2ug3uLP1A3DE79J7bSEqn2AS46I_u4_yLzdSRKBdoMRcLaL93-5lmJaaJAvmgRl79g5TUpY3IKkkZ_DVq1RJVnbAlaGpdVIbvgmlRu_pErqBbfw7g9T9ly5l-VjQejO4EscFtkMH 2021-11-30 10:00:04.233 Info HttpClient: Http response 200 from http://balance.redacted.com/auth/y-kKLYo9Jli31GgypLN5vW_7GyscChSJaEGU_c4buZFo19UEQjrwF0lh0YcZp0wa3nvE6m2f5xNJh0mqwSE_MpFsxm21sUYgQCc2W4FYU4ZYAFnftTd8UyRRazXJ7yzKJpiwqsAmwq9Q5Dx1_2YKP9VzI5sg0X3jYivLQaHTTuMscYKqsO2zoHjV87F3-DTjCk1cb7rFUy9MrBhM96gm3DYSATKQm8wRJbQHUSe6yR5rlSH5MI7xvHW6ARLof7krRJF6ISXoKDBezsEP-P3WbJ0K5xCDunJUQsouim9h8to5l0_hAP9Wc1bm6l24l-fxpZIwyVNUZpHAL1K_FLGgxaRQOCdXqajbslzAwGTR15ZtD-J4lKilmGgeKPXPH_bcgLoi7jL00dLUXqj5HuU_PmnuMqW5edeHLzNnPXRo1ag8-S_obXxkG1Kxxuh3QmyN56iz58SSh2MpFgpKNCFxp9DtVnwzgEtCEAC11sbcmoVpg8bMGAwPaQMiyiz7lOpbaoJjVFrqoaBF8wJ1ooyQit8CsEorZopGec8_9AwycHL_szPIIOsOEhdy2ug3uLP1A3DE79J7bSEqn2AS46I_u4_yLzdSRKBdoMRcLaL93-5lmJaaJAvmgRl79g5TUpY3IKkkZ_DVq1RJVnbAlaGpdVIbvgmlRu_pErqBbfw7g9T9ly5l-VjQejO4EscFtkMH after 3118ms. HeadersServer=nginx, Date=Tue, 30 Nov 2021 16:00:04 GMT, Connection=close, Access-Control-Allow-Origin=* 2021-11-30 10:00:04.233 Info SharedHttpPipelineSource: Beginning SharedHttpPipelineSource stream to /var/lib/emby/transcoding-temp/db9ba82a1095419fb6a570247360a390.ts 2021-11-30 10:00:04.233 Info M3UTunerHost: Live stream opened after 3486.8765ms 2021-11-30 10:00:04.233 Info LiveTV: Returning mediasource streamId c290404b450d950b9de34e7b84a2368a, mediaSource.Id c290404b450d950b9de34e7b84a2368a, mediaSource.LiveStreamId null 2021-11-30 10:00:04.237 Info MediaSourceManager: Live stream opened: {"Protocol":"Http","Id":"c290404b450d950b9de34e7b84a2368a","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/db9ba82a1095419fb6a570247360a390/stream.ts","Type":"Default","Container":"mpegts","IsRemote":false,"ContainerStartTimeTicks":53330,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_c290404b450d950b9de34e7b84a2368a","RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"h264","StreamStartTimeTicks":333330,"TimeBase":"1/90000","CodecTimeBase":"1/60","VideoRange":"SDR","DisplayTitle":"720p H264","NalLengthSize":"0","IsInterlaced":false,"BitRate":6000000,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":720,"Width":1280,"AverageFrameRate":30,"RealFrameRate":30,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"aac","StreamStartTimeTicks":53330,"TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Und AAC stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":95933,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Profile":"LC","Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"}],"Formats":[],"Bitrate":6095933,"RequiredHttpHeaders":{"User-Agent":"VLC/3.0.11"},"ReadAtNativeFramerate":false} 2021-11-30 10:00:04.237 Info LiveTV: Recording ensure file unique input: /mnt/Plex/Emby/TV Shows/Heartland (2007)/Season 12/Heartland S12E03 Just Breathe.ts 2021-11-30 10:00:04.237 Info LiveTV: Recording ensure file unique result: /mnt/Plex/Emby/TV Shows/Heartland (2007)/Season 12/Heartland S12E03 Just Breathe.ts 2021-11-30 10:00:04.237 Info LiveTV: Will record to /mnt/Plex/Emby/TV Shows/Heartland (2007)/Season 12/Heartland S12E03 Just Breathe.ts for 64.92937011833334 minutes. 2021-11-30 10:00:04.251 Info LiveTV: Triggering refresh on /mnt/Plex/Emby/TV Shows/Heartland (2007)/Season 12/Heartland S12E03 Just Breathe.ts 2021-11-30 10:00:04.253 Info LiveTV: Refreshing recording parent /mnt/Plex/Emby/TV Shows 2021-11-30 10:00:04.253 Info LiveTV: Copying recording stream to file /mnt/Plex/Emby/TV Shows/Heartland (2007)/Season 12/Heartland S12E03 Just Breathe.ts 2021-11-30 10:00:04.473 Info HttpClient: GET https://api.themoviedb.org/3/find/tt1094229?api_key=f6bd687ffa63cd282b6ff2c6877f2669&external_source=imdb_id 2021-11-30 10:00:04.776 Info HttpClient: GET https://api.themoviedb.org/3/tv/14929?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=credits,images,keywords,external_ids,videos,content_ratings&language=en&include_image_language=en,null 2021-11-30 10:00:04.813 Info HttpClient: GET https://private.omdbapi.com?apikey=fe53f97e&i=tt1094229&plot=short&tomatoes=true&r=json 2021-11-30 10:00:04.939 Info HttpClient: GET https://www.thetvdb.com/api/B89CE93890E9419B/series/82701/all/en.zip 2021-11-30 10:00:05.033 Info HttpClient: GET https://webservice.fanart.tv/v3/tv/82701?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2021-11-30 10:00:05.686 Info App: Creating virtual unaired episode Heartland 15x8 2021-11-30 10:00:05.686 Info App: Creating Season Season 15 entry for Heartland 2021-11-30 10:00:05.701 Info App: Creating virtual unaired episode Heartland 15x9 2021-11-30 10:00:26.184 Info SharedHttpPipelineSource: Remote server closed stream https://redacted.com/202redacted/redacted/redacted 2021-11-30 10:00:26.185 Info SharedHttpPipelineSource: Retry opening stream https://redacted.com/202redacted/redacted/redacted 2021-11-30 10:00:26.185 Info SharedHttpPipelineSource: Opening SharedHttpPipelineSource Live stream from https://redacted.com/202redacted/redacted/redacted 2021-11-30 10:00:26.185 Info HttpClient: GET https://redacted.com/202redacted/redacted/redacted 2021-11-30 10:00:26.449 Info HttpClient: Http response 404 from https://redacted.com/202redacted/redacted/redacted after 264ms. HeadersDate=Tue, 30 Nov 2021 16:00:26 GMT, Transfer-Encoding=chunked, Connection=keep-alive, Cache-Control=no-store, must-revalidate, no-cache, Access-Control-Allow-Origin=*, CF-Cache-Status=DYNAMIC, Expect-CT=max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct", Report-To={"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=wsZf1CvHvf%2FTKtEby3adbV%2BgTN33cmjHCADF1uSfLEtS7PPWGqfLq36Rp%2FNz06DhxCjhWDydIBXOl%2BTF2e9FeVcBMuOCUPdPnessV6ZZzuxV9vv0AfPRL6XxD8sfbdUKqGnr"}],"group":"cf-nel","max_age":604800}, NEL={"success_fraction":0,"report_to":"cf-nel","max_age":604800}, Server=cloudflare, CF-RAY=6b6549e3b8a162bd-ORD, Alt-Svc=h3=":443"; ma=86400, h3-29=":443"; ma=86400, h3-28=":443"; ma=86400, h3-27=":443"; ma=86400 2021-11-30 10:00:26.452 Error SharedHttpPipelineSource: Give up retries copying live stream https://redacted.com/202redacted/redacted/redacted *** Error Report *** Version: 4.6.4.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-90-generic (buildd@lgw01-amd64-054) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #101-Ubuntu SMP Fri Oct 15 20:00:55 UTC 202 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 12 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.OpenStream(IDisposable connectionContext, MediaSourceInfo mediaSource, String url, MediaProtocol protocol, CancellationToken cancellationToken, Int32 recursion) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.<>c__DisplayClass8_0.<<StartStreaming>b__0>d.MoveNext() Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2021-11-30 10:00:26.461 Error SharedHttpPipelineSource: Error copying live stream. *** Error Report *** Version: 4.6.4.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-90-generic (buildd@lgw01-amd64-054) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #101-Ubuntu SMP Fri Oct 15 20:00:55 UTC 202 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 12 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.OpenStream(IDisposable connectionContext, MediaSourceInfo mediaSource, String url, MediaProtocol protocol, CancellationToken cancellationToken, Int32 recursion) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.<>c__DisplayClass8_0.<<StartStreaming>b__0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.<>c__DisplayClass8_0.<<StartStreaming>b__0>d.MoveNext() Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2021-11-30 10:00:26.461 Info SharedHttpPipelineSource: SharedHttpPipelineSource is done streaming. 2021-11-30 10:00:26.461 Info SharedHttpPipelineSource: Deleting temp files /var/lib/emby/transcoding-temp/db9ba82a1095419fb6a570247360a390.ts Edited December 1, 2021 by vdrover
Carlo 4561 Posted December 10, 2021 Posted December 10, 2021 Emby is reporting a 404 error trying to get this stream from Cloudflare which is being used to carry the stream which is pretty odd. It appears to me to be a problem with the stream to get a 404 response. Those headers do not look correct for streaming Live TV through a content distribution network. Do you have issues on multiple channels but not all channels? Http response 404 from https://redacted.com/202redacted/redacted/redacted after 264ms. HeadersDate=Tue, 30 Nov 2021 16:00:26 GMT, Transfer-Encoding=chunked, Connection=keep-alive, Cache-Control=no-store, must-revalidate, no-cache, Access-Control-Allow-Origin=*, CF-Cache-Status=DYNAMIC, Expect-CT=max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct", Report-To={"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=wsZf1CvHvf%2FTKtEby3adbV%2BgTN33cmjHCADF1uSfLEtS7PPWGqfLq36Rp%2FNz06DhxCjhWDydIBXOl%2BTF2e9FeVcBMuOCUPdPnessV6ZZzuxV9vv0AfPRL6XxD8sfbdUKqGnr"}],"group":"cf-nel","max_age":604800}, NEL={"success_fraction":0,"report_to":"cf-nel","max_age":604800}, Server=cloudflare, CF-RAY=6b6549e3b8a162bd-ORD, Alt-Svc=h3=":443"; ma=86400, h3-29=":443"; ma=86400, h3-28=":443"; ma=86400, h3-27=":443"; ma=86400
