unitymedia 2 Posted November 30, 2021 Posted November 30, 2021 Добрый день , emby app на Fire TV Stick 4K воспроизводится не правильно, к примеру на приставке с android tv видеоматериал воспроизводиться правильно . На fire tv 4k
ebr 16332 Posted November 30, 2021 Posted November 30, 2021 Hi. This is a home video and it is playing upside down? Can you be sure the orientation in the video metadata is correct?
unitymedia 2 Posted December 1, 2021 Author Posted December 1, 2021 Еще раз, на приставке android tv правильно воспроизводится, через броузер тоже правильно воспроизводится, ошибка только на fire tv 4k
ebr 16332 Posted December 1, 2021 Posted December 1, 2021 9 minutes ago, unitymedia said: Again, on the android TV set-top box is correctly reproduced, through the browser is also correctly reproduced, the error is only on fire tv 4k Now that is really strange as the Android TV and the Fire are using the exact same player. What is the app version on your Fire?
ebr 16332 Posted December 9, 2021 Posted December 9, 2021 Hi. Sorry, I do not know how the Fire could be different from the same version on a different device but the screen shot above does not look like it is from the Fire TV app. If it is, exactly where was that?
ebr 16332 Posted December 11, 2021 Posted December 11, 2021 On 11/29/2021 at 8:12 PM, unitymedia said: На fire tv 4k Hi. Where were you in the app when you took this screen shot?
ebr 16332 Posted December 11, 2021 Posted December 11, 2021 Hi. No, the screen shot I quoted. The one with the video with the big play button in the middle of it....
ebr 16332 Posted December 11, 2021 Posted December 11, 2021 14 minutes ago, unitymedia said: smartphone You said the problem was on the Fire TV...
unitymedia 2 Posted December 11, 2021 Author Posted December 11, 2021 Телефоном фотографировал как выглядит на экране телевизора .
ebr 16332 Posted December 12, 2021 Posted December 12, 2021 Okay, exactly where were you in the TV app when you took that picture? How did you get to that screen?
unitymedia 2 Posted December 15, 2021 Author Posted December 15, 2021 Включил приложение, выбрал видеоролик, нажал воспроизведение .
ebr 16332 Posted December 15, 2021 Posted December 15, 2021 6 hours ago, unitymedia said: I turned on the application, selected a video, pressed play. Hi. Exactly where did you "select a video" and by that do you mean you focused it or opened a detail page for it? What is the type of library this video is in? Is it Home Videos and Photos? That screen shot looks like it is from a photo slide show instead of from video playback. Is the video actually playing? What happens if you hit the "Play" button on your remote when that screen is up?
