lh1983 7 Posted September 12, 2014 Posted September 12, 2014 Here's my setup: MBS is running as a service on my HTPC. I recently built a NAS and added it to my network. I want to store some TV shows on the NAS and have them play in MediaBrowser Theater. The NAS is running OpenMediaVault 1.0 kralizec. On one hard drive on the NAS, I created a folder called "TV." When I open up the MediaBrowser configuration tool, and start to create a new library, it finds my NAS on the network, but when I try to go to my TV directory, there fields do not populate. The only option is the "go up one level" dots (..). Is there something I need to do on my NAS to make MediaBrowser Server see the shared folder?
ebr 16306 Posted September 12, 2014 Posted September 12, 2014 It doesn't sound like you actually put anything in your TV folder. Did you?
lh1983 7 Posted September 13, 2014 Author Posted September 13, 2014 It doesn't sound like you actually put anything in your TV folder. Did you? I did, turns out the problem was my HTPC hadn't connected to the computer with a login name/password. Once I did that, I was able to add the TV folder to the library. My wife is currently watching her shows in the living room and giggling at them. MBT saved the day on a day she was feeling sick, so, thanks guys.
