wavyroel 3 Posted November 28, 2021 Posted November 28, 2021 (edited) Dear Members, Recently I bought a Samsung Smart TV Tizen and tried to watch dual audio files on it. For some reason it does not work. For your info, when I test the files on a PC they work properly. I can switch between audio paths with no problem and this is also the case for the Emby app on my phone, desktop whatsoever. However when I try to switch to the Japanese audio path on Tizen nothing happens. It shows that its selected but in theory there is no audio switch. Does someone else have any idea how to solve this or is this a known issue? Emby Version: 1.1.08 Installation: USB Regards, Roel Edited November 28, 2021 by wavyroel
FrostByte 5453 Posted November 28, 2021 Posted November 28, 2021 What model TV? I assume it's a 2021 if you just bought it. There is a similar discussion which only affects 2021 owners here 1
wavyroel 3 Posted November 28, 2021 Author Posted November 28, 2021 @FrostByteIve read through this and it is indeed the same exact problem, I have a 2021 model too. Could you advise me on the fastest way to strip one audio track from multiple files? What software do I use for that? Regards, Roel
Spaceboy 2573 Posted November 28, 2021 Posted November 28, 2021 tdarr. has a file watcher function too
SamES 1084 Posted November 30, 2021 Posted November 30, 2021 On 29/11/2021 at 08:31, wavyroel said: Does someone else have any idea how to solve this or is this a known issue? I need to add some logging so that we can find out what has changed in this model. Working on it... 1
