Paxtor 8 Posted November 28, 2021 Posted November 28, 2021 Hello, I bought a M9Plus I have a problem with port forwarding. 1. I connect on app. deco with my mobile and I add ip home lan and port 8096 udp/tcp and doesn't work I trying to connect Remote (WAN) access: http://ip... I also have an open port on the modem 8096... If I try with my old router it's working fine. does anyone have Deco M9Plus?
Luke 42237 Posted November 28, 2021 Posted November 28, 2021 Hi, what exactly doesn't work? I've configured this on a Deco before and it worked just fine when I tried it.
Paxtor 8 Posted November 30, 2021 Author Posted November 30, 2021 (edited) Hi Luke, If I'm outside and connected on 4g 5g I can't connect on server.... because I think is port problem.... I try this on my old ruter and working fine..... If I try wit my deco doesn't work:/ or I must different setup? can you wrote step by step tutorial? Edited November 30, 2021 by Paxtor
Happy2Play 9811 Posted November 30, 2021 Posted November 30, 2021 Sounds like Port Forwarding or different DHCP pools on each router. How to set up Port Forwarding feature on the Deco? | TP-Link
Paxtor 8 Posted December 1, 2021 Author Posted December 1, 2021 Happy2Play please check picture. I did that but doesn't work. I have my modem in bridge mode.
Luke 42237 Posted December 4, 2021 Posted December 4, 2021 Are you sure you're using the correct remote ip address?
Paxtor 8 Posted December 4, 2021 Author Posted December 4, 2021 8 hours ago, Luke said: Are you sure you're using the correct remote ip address? shield tv have this ip
Paxtor 8 Posted December 5, 2021 Author Posted December 5, 2021 how can I test port on deco? On 12/4/2021 at 2:35 AM, Luke said: Are you sure you're using the correct remote ip address? shield tv have this ip
Luke 42237 Posted December 5, 2021 Posted December 5, 2021 27 minutes ago, Paxtor said: how can I test port on deco? shield tv have this ip I mean the remote address for when you're connecting out of network. where did you get that from?
Paxtor 8 Posted December 6, 2021 Author Posted December 6, 2021 thanx all for helping me I resolved a problem I added another ip from the modem and now it works. Thank You.
