marriedman 85 Posted November 27, 2021 Posted November 27, 2021 TLDR; - Where is the library stored on Arch based systems? Long time Kodi user, brand spanking new emby user. I've got so many questions because this is so different, but I think is the one that I should start with. I have images that I do not want; movies, collections, & TV show posters that are not what I meticulously chose. I prefer to set everything up in MediaElch then add them to my library. This allows me to have certain TV show episodes in production order (what the writer wanted instead of the producers, Babylon 5 for example) as well as information I find important that I will add to the plot or outline or description... sorry, I get sidetracked easily. I see where I can disable any internet scraping and I am cool with that, except I lose the Actor images since I cannot have the .actors folder recognized and the People Backup plugin no longer works until it is updated... sorry did it again! I just want to delete the library.db but I cannot find the darn thing. According to the forum, the Dashboard tells me the following paths: /var/lib/emby/metadata (or logs or cache...) but the emby folder doesn't exist. I do have a /usr/lib/emby-server/ path, but there are no metadata, log, nor cache folder in that path. I mean, I guess I could do a purge uninstall, but that seems a bit extreme if I am just going to reinstall it anyway. Thanks in advance!
Luke 42246 Posted November 28, 2021 Posted November 28, 2021 Quote Where is the library stored on Arch based systems? Hi, the top of the server log will display all of the various paths used by the server. Please let us know if this helps. Thanks.
marriedman 85 Posted November 28, 2021 Author Posted November 28, 2021 33 minutes ago, Luke said: Hi, the top of the server log will display all of the various paths used by the server. Please let us know if this helps. Thanks. Thanks for reply Luke, I feel special to have such an auspicious admin take notice of my post! It's like a celebrity sighting since I have seen your name everywhere while looking for my answers before posting. Unfortunately the logs just repeats what the Dashboard says: 2021-11-27 11:58:18.781 Info Main: Application path: /usr/lib/emby-server/EmbyServer.dll 2021-11-27 11:58:19.038 Info Main: Emby Command line: /usr/lib/emby-server/EmbyServer.dll -programdata /var/lib/emby -ffdetect /usr/bin/ffdetect-emby -ffmpeg /usr/bin/ffmpeg-emby -ffprobe /usr/bin/ffprobe-emby -restartexitcode 3 Operating system: Linux version 5.15.2-2-MANJARO (builduser@fv-az131-873) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Sat Nov 13 19:25:38 UTC 2021 Framework: .NET Core 3.1.20 OS/Process: x64/x64 Runtime: usr/share/dotnet/shared/Microsoft.NETCore.App/3.1.20/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /usr/lib/emby-server 2021-11-27 11:58:19.086 Info App: Application version: 4.6.4.0 2021-11-27 11:58:19.089 Info App: Loading assemblies 2021-11-27 11:58:19.111 Info App: File /var/lib/emby/plugins/DvdMounter.dll has version 1.0.0.0 2021-11-27 11:58:19.112 Info App: File /usr/lib/emby-server/plugins/DvdMounter.dll has version 1.0.0.0 <snipped> 2021-11-27 11:58:19.124 Info App: Not loading PeopleBackup.dll 1.4.1.0 because the minimum supported version is 1.5.0. Please update to the newer version I snipped out the repeating paths for emby/plugins/ (which doesn't exist) & emby-server/plugins, then snipped to the error about PeopleBackup. I've attached a picture of the /var/lib/ folder in my file manager to show that the emby folder is not there. The contents of my emby-server folder are: dashboard-ui plugins runtimes traystrings Emby.ActivityLog.dll Emby.Api.dll Emby.Codecs.dll Emby.Codecs.Dxva.dll Emby.Drawing.dll Emby.Drawing.Skia.dll Emby.Ffmpeg.Base.dll Emby.Ffmpeg.dll Emby.Ffmpeg.Lib.dll Emby.LiveTV.dll Emby.LocalMetadata.dll Emby.Media.Model.dll Emby.Naming.dll Emby.Notifications.dll Emby.Photos.dll Emby.ProcessRun.dll Emby.Providers.dll EmbyServer Emby.Server.Connect.dll EmbyServer.deps.json EmbyServer.dll Emby.Server.Implementations.dll Emby.Server.MediaEncoding.dll EmbyServer.runtimeconfig.json Emby.Server.Sync.dll Emby.Sqlite.dll Emby.Web.dll Emby.Web.GenericEdit.dll libSkiaSharp.so MediaBrowser.Common.dll MediaBrowser.Controller.dll MediaBrowser.Model.dll Microsoft.AspNetCore.Connections.Abstractions.dll Microsoft.AspNetCore.Hosting.Abstractions.dll Microsoft.AspNetCore.Hosting.dll Microsoft.AspNetCore.Hosting.Server.Abstractions.dll Microsoft.AspNetCore.Http.Abstractions.dll Microsoft.AspNetCore.Http.dll Microsoft.AspNetCore.Http.Extensions.dll Microsoft.AspNetCore.Http.Features.dll Microsoft.AspNetCore.Server.Kestrel.Core.dll Microsoft.AspNetCore.Server.Kestrel.dll Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.dll Microsoft.AspNetCore.WebSockets.dll Microsoft.AspNetCore.WebUtilities.dll Microsoft.Extensions.Configuration.Abstractions.dll Microsoft.Extensions.Configuration.Binder.dll Microsoft.Extensions.Configuration.CommandLine.dll Microsoft.Extensions.Configuration.dll Microsoft.Extensions.Configuration.EnvironmentVariables.dll Microsoft.Extensions.Configuration.FileExtensions.dll Microsoft.Extensions.Configuration.Json.dll Microsoft.Extensions.Configuration.UserSecrets.dll Microsoft.Extensions.DependencyInjection.Abstractions.dll Microsoft.Extensions.DependencyInjection.dll Microsoft.Extensions.FileProviders.Abstractions.dll Microsoft.Extensions.FileProviders.Physical.dll Microsoft.Extensions.FileSystemGlobbing.dll Microsoft.Extensions.Hosting.Abstractions.dll Microsoft.Extensions.Hosting.dll Microsoft.Extensions.Logging.Abstractions.dll Microsoft.Extensions.Logging.Configuration.dll Microsoft.Extensions.Logging.Console.dll Microsoft.Extensions.Logging.Debug.dll Microsoft.Extensions.Logging.dll Microsoft.Extensions.Logging.EventLog.dll Microsoft.Extensions.Logging.EventSource.dll Microsoft.Extensions.ObjectPool.dll Microsoft.Extensions.Options.ConfigurationExtensions.dll Microsoft.Extensions.Options.dll Microsoft.Extensions.Primitives.dll Microsoft.Net.Http.Headers.dll Microsoft.OpenApi.dll Microsoft.Win32.SystemEvents.dll PlaylistsNET.dll RSSDP.dll ServiceStack.Text.dll SharpCompress.dll SharpDX.Direct3D11.dll SharpDX.Direct3D9.dll SharpDX.dll SharpDX.DXGI.dll SharpDX.MediaFoundation.dll SimpleInjector.dll SkiaSharp.dll SocketHttpListener.dll SQLitePCL.pretty.dll SQLitePCLRawEx.core.dll System.Diagnostics.EventLog.dll System.IO.Pipelines.dll System.Net.WebSockets.WebSocketProtocol.dll System.ServiceProcess.ServiceController.dll System.Text.Encoding.CodePages.dll System.Text.Encodings.Web.dll System.Threading.Tasks.Dataflow.dll There is no library.db to be found. I'm honestly kind of lost really.
Luke 42246 Posted November 29, 2021 Posted November 29, 2021 database files are under /var/lib/emby/data
marriedman 85 Posted November 29, 2021 Author Posted November 29, 2021 9 minutes ago, Luke said: database files are under /var/lib/emby/data That's just it, they aren't there. Here is the contents of the /var/lib folder: AccountsService/ alsa/ apparmor/ arpd/ colord/ ctdb/ dbus/ dhclient/ dhcpcd/ ex/ flatpak/ geoclue/ gssproxy/ hp/ krb5kdc/ lirc/ logrotate.status machines/ mhwd/ misc/ mpd/ NetworkManager/ nfs/ ntp/ os-prober/ PackageKit/ pacman/ pacman-mirrors/ portables/ private/ rpcbind/ samba/ sddm/ snapd/ systemd/ tlp/ tpm2-tss/ udisks2/ upower/ usb_modeswitch/ xkb/ emby@ At the bottom is a file with a @ at the end. Nothing happens when I try to open it though. If it is a symlink to the emby-server folder, then the database files are not stored there.
marriedman 85 Posted November 29, 2021 Author Posted November 29, 2021 I've done a file search for my entire filesystem for library.db and come up empty. Is it called something different on Linux?
Solution Luke 42246 Posted November 29, 2021 Solution Posted November 29, 2021 It's created by a user named emby, so maybe you just can't see it? 1
marriedman 85 Posted November 29, 2021 Author Posted November 29, 2021 1 minute ago, Luke said: It's created by a user named emby, so maybe you just can't see it? Aaah, there is something I never even thought of. This might be related to those permission posts I keep seeing? I will look into that. Thanks for the idea Luke, I will report back. 1
marriedman 85 Posted November 29, 2021 Author Posted November 29, 2021 That was the issue Luke. Thank you for your help! If anyone else searches for this solution - I just shutdown the server via the dashboard then launched a file manager as root and renamed the library.db to library.db.old and restarted. I'll report back once the new scan is complete.
marriedman 85 Posted November 29, 2021 Author Posted November 29, 2021 It took me a little while to find it, but it looks like the true file path on Manjaro for everything is /var/lib/private/emby/ I am not that good with the konsole/terminal so I used a root file manager (Dolphin) to poke around. I don't quite understand why everything is so obfuscated though. @Luke - Since it isn't on in the FAQ or commonly found on the forums here, would it be a safe assumption that this was a decision made by the Arch package maintainer?
Luke 42246 Posted December 4, 2021 Posted December 4, 2021 I don't know if that' something specific to Manjaro or our Arch Linux package, but @alucryd may have some insight. Thanks. 1
alucryd 318 Posted December 4, 2021 Posted December 4, 2021 (edited) 8 hours ago, Luke said: I don't know if that' something specific to Manjaro or our Arch Linux package, but @alucryd may have some insight. Thanks. That is specific to arch based systems, specifically the arch package which uses systemd's dynamic users feature. You can still find the programdata in `/var/lib/emby` while the systemd service is running, but that is actually a link to `/var/lib/private/emby` and when the service is off `/var/lib/emby` doesn't exist. Note that a regular user won't be able to access the private directory, you need root permissions. Edited December 4, 2021 by alucryd
marriedman 85 Posted December 4, 2021 Author Posted December 4, 2021 That pretty much sums up everything that I discovered. I had to look up that dynamic user feature. That explains why I had so much trouble with the permissions!. Thanks for weighing in alucryd.
