bluemonkey07 590 Posted September 18, 2014 Posted September 18, 2014 (edited) yes I'm sure Edited September 20, 2014 by Vidman
snazy2000 345 Posted September 18, 2014 Author Posted September 18, 2014 I haven't had chance to take proper look. I'm very busy atm
Logos302 86 Posted September 18, 2014 Posted September 18, 2014 ah ok. It cool, just didn't see any comment about it for a while (Three days, gee getting impatient I guess). Any thank you for looking into it when ever you get a chance.
Logos302 86 Posted September 19, 2014 Posted September 19, 2014 I guess my logs didn't show anything? Or shed any light as to why I can't play anything.
bluemonkey07 590 Posted September 24, 2014 Posted September 24, 2014 Hi snazy any chance you have had a spare minute to look at this yet?
bluemonkey07 590 Posted October 4, 2014 Posted October 4, 2014 @@snazy2000 have you had a chance to look at this yet?
snazy2000 345 Posted October 4, 2014 Author Posted October 4, 2014 Its on my to do list after looking after my daughter im affraid :/
bluemonkey07 590 Posted October 4, 2014 Posted October 4, 2014 Of course mate, no worries just checking in:)
snazy2000 345 Posted October 5, 2014 Author Posted October 5, 2014 @@Vidman ive had a chance to take a look at what is being returned from your favs and i have found the issue I will get it fixed asap !
bluemonkey07 590 Posted October 5, 2014 Posted October 5, 2014 What was the issue out of curiosity? Do I need to leave my following list as public?
snazy2000 345 Posted October 5, 2014 Author Posted October 5, 2014 I dont think you do. It was becuase you had a show in yiur favorites which yhen made it return different data which it then didnt know how to parse
cmcv 3 Posted October 6, 2014 Posted October 6, 2014 (edited) Hi the update has worked on my system too, to show all my favorites. However every time I pick a station listed in favorites it goes to Power DVD & then nothing happens... what am i doing wrong? or missing? ..... Ok it works in the server ok & plays their however does it work through mbc in media centre? Edited October 6, 2014 by cmcv
snazy2000 345 Posted October 6, 2014 Author Posted October 6, 2014 There are issues with mbc and tunein and dont know why. I know works fine in roku
ebr 16340 Posted October 6, 2014 Posted October 6, 2014 Power DVD cannot play a streaming url I'm pretty sure. You need to change your MBC configuration to not launch the external player for whatever file type that is.
snazy2000 345 Posted October 7, 2014 Author Posted October 7, 2014 I tried it today and nothing happens doesnt even seem to request it from mbs
ebr 16340 Posted October 7, 2014 Posted October 7, 2014 snazy - the problem is here: http://mediabrowser.tv/community/index.php?/topic/10748-tunein-plugin-on-wmc-win7-mb-classic/?p=133749 The plug-in is not filling in the Path to the video.
snazy2000 345 Posted October 7, 2014 Author Posted October 7, 2014 Its audio but i get what you mean. I dont get why it works for all other clients if your saying the path isnt there :S
ebr 16340 Posted October 7, 2014 Posted October 7, 2014 The playback mechanisms in MBC are all designed around the path because they date back to MB 2 and I use that value to determine whether or not I can direct play something. All the other clients were written for MB 3 and are simply asking the server to stream the item or using media sources instead.
snazy2000 345 Posted October 7, 2014 Author Posted October 7, 2014 The path is fetched by using "GetChannelItemMediaInfo" does that mean MBC doesnt support that?
ebr 16340 Posted October 7, 2014 Posted October 7, 2014 The path is fetched by using "GetChannelItemMediaInfo" does that mean MBC doesnt support that? No, not at this time. MBC is looking at the standard "Path" property that exists on all items as all of its playback logic is generic and most of it still dates back to MB 2.
snazy2000 345 Posted October 7, 2014 Author Posted October 7, 2014 Thats why its currently not working then Vimeo, twitch, rev 3,ITV, Cnet, vevo all shouldnt work then? 1
ebr 16340 Posted October 7, 2014 Posted October 7, 2014 I know Vimeo used to because I tested it but that was a while ago.
ebr 16340 Posted October 7, 2014 Posted October 7, 2014 I just tested again and Vimeo still works. The difference is that Tune-in is presenting audio items and those are handled differently in MBC and are not as intelligent as Videos about streaming. I'll have to look and see if I can improve it.
