Spaceboy 2573 Posted September 13, 2014 Posted September 13, 2014 I didn't change anything like that, presume that's for other people to follow you? Sent from my iPhone using Tapatalk
bluemonkey07 590 Posted September 13, 2014 Posted September 13, 2014 But the mb3 plugin has no password setting so I assume it can only access public info from tunein
TheShanMan 41 Posted September 13, 2014 Posted September 13, 2014 I'm also getting an error trying to play stations and I just updated the tunein plugin. It also isn't displaying my favorites correctly. I've got 4 favorites set in tunein.com but in MB I only see 2 of them. 1 is showing up once in the MB list, and the other is showing up 3 times, plus each of the 3 say "not supported".
snazy2000 345 Posted September 14, 2014 Author Posted September 14, 2014 Need screenshots and logs please
bluemonkey07 590 Posted September 14, 2014 Posted September 14, 2014 dl=0https://www.dropbox.com/sh/nbcmhhtbmcozwq2/AABzF0nk6_H69PMswbVOy-fxa?dl=0 heres my log what screen shots do you need?
snazy2000 345 Posted September 14, 2014 Author Posted September 14, 2014 Could you send me a picture of the "private" thing in tune in and is there way to change it.
bluemonkey07 590 Posted September 14, 2014 Posted September 14, 2014 yea I tried changing it to public but still have no favorites.....I've added a screen shot to the dropbox link above
ebr 16340 Posted September 14, 2014 Posted September 14, 2014 FYI - How to Create & Post a Screenshot It is usually much easier to see the screenshots embedded in the forum.
bluemonkey07 590 Posted September 14, 2014 Posted September 14, 2014 FYI - How to Create & Post a Screenshot It is usually much easier to see the screenshots embedded in the forum. I tried to embed it but the file size was too big
ebr 16340 Posted September 14, 2014 Posted September 14, 2014 I tried to embed it but the file size was too big Using the exact method in that post? Not adding it as an attachment, but using the image button on the tool bar?
Spaceboy 2573 Posted September 14, 2014 Posted September 14, 2014 Yep mines public actually, I didn't set this though. Connected with my google+ account so I guess it's public automatically through that
Glyde62 50 Posted September 15, 2014 Posted September 15, 2014 All my channels show up fine but when I click on play nothing happens?
snazy2000 345 Posted September 15, 2014 Author Posted September 15, 2014 @@Vidman can you try setting it to public. @@Glyde62 need logs
bluemonkey07 590 Posted September 15, 2014 Posted September 15, 2014 As mentioned already I tried that with no success.... Or did you mean you need logs with it set to public
snazy2000 345 Posted September 15, 2014 Author Posted September 15, 2014 Can u set to public and leave it on that. You will need to wait 12 hours from last viewing the fab channel due to caching
Logos302 86 Posted September 15, 2014 Posted September 15, 2014 (edited) OK, I've got it installed, and it's reading in my favourites, but when clicking play (In the web client, havn't tried any others yet) nothing happens. I'll post the logs if some one could tell me which log to post. The server log?? or is there a plugin log? Edited September 15, 2014 by Logos302
Logos302 86 Posted September 16, 2014 Posted September 16, 2014 Here is the server log, should be right at the bottom. https://www.dropbox.com/s/vgadbs786wh6uye/server-63546336000.txt?dl=0
coolspot 22 Posted September 16, 2014 Posted September 16, 2014 Anyone have any luck getting this to work in Media Browser Classic? When I have this plugin loaded, MBC won't load at all.
Logos302 86 Posted September 16, 2014 Posted September 16, 2014 MBC loads fine here, but I can't use it as of yet. Hopefully my log will help solve this issue.
bluemonkey07 590 Posted September 16, 2014 Posted September 16, 2014 Can u set to public and leave it on that. You will need to wait 12 hours from last viewing the fab channel due to cachingStill no favourites for me
bluemonkey07 590 Posted September 18, 2014 Posted September 18, 2014 Hi snazy2000 do you have any other suggestions as to populating my tune in favourites?
snazy2000 345 Posted September 18, 2014 Author Posted September 18, 2014 Are they deft in you favourites and you've entered you username in the config (as it says on tune in config page even case)
