sakle2k 12 Posted November 27, 2021 Posted November 27, 2021 Running v. 4.6.7.0 on Win10. Channel guide is empty. When I go to Live TV > Setup, there are no providers in the Lineup dropdown beneath my zip code. I deleted the existing guide data source and tried to add it in again but there is nothing populated in the Lineup dropdown. This is the 3rd or 4th time this has happened in the past month or so but it seems to "fix" itself. Any suggestions? Server log is attached. Thanks. embyserver (2).txt
Carlo 4561 Posted November 27, 2021 Posted November 27, 2021 Hi, What guide source are you trying to use?
sakle2k 12 Posted November 27, 2021 Author Posted November 27, 2021 Hi, The Emby guide source. I just tried it and it's working again. Do you have any idea why this keeps happening?
Carlo 4561 Posted November 27, 2021 Posted November 27, 2021 No I don't but I'd suggest checking it daily. If you the guide disappear again, upload the current as well as day before logs which could help show what happened.
Luke 42237 Posted November 27, 2021 Posted November 27, 2021 If you manually refresh the guide data in emby server, how does it look once that has completed?
sakle2k 12 Posted November 27, 2021 Author Posted November 27, 2021 It refreshes correctly and everything looks fine.
Luke 42237 Posted November 28, 2021 Posted November 28, 2021 OK let us know if you see this again. Thanks.
sakle2k 12 Posted November 29, 2021 Author Posted November 29, 2021 Yes, so far still good. Thanks for following up. 2
