Yorin 0 Posted November 26, 2021 Posted November 26, 2021 Since the latest update, I can no longer play sound of any video files to multiple HomePod speakers. Sound only plays through the standard TV speakers set in Apple TV settings. I can't add other HomePods to play sound on additional speakers. This does work with other players and has worked in the past.
Luke 42241 Posted November 27, 2021 Posted November 27, 2021 Hi there, if you look in the app settings, is the mpv player option enabled?
Luke 42241 Posted November 28, 2021 Posted November 28, 2021 If you disable it and use the native player instead, how does that compare?
Yorin 0 Posted November 28, 2021 Author Posted November 28, 2021 Hi Luke, when disabled it works again to play audio on multiple HomePods. Thanks!!
Luke 42241 Posted November 29, 2021 Posted November 29, 2021 14 hours ago, Yorin said: Hi Luke, when disabled it works again to play audio on multiple HomePods. Thanks!! Thanks for the feedback.
