Luke 42255 Posted January 13, 2022 Posted January 13, 2022 On 1/1/2022 at 6:21 PM, lethtel said: Hi, Just to add some more if it can help (and seems to be the same behaviour somewhere) : Besides "traditionnal" problem of subtitles not showing up by manual search (Magnum PI (2018) 04x01, looking for french subs, TVdb and IMdb IDs filled) it seems i have a bonus : i would say there is a problem with addic7ed requests (at least on my side). If i manually search for an item : I find it. If i trigger a automatic download from scheduled task i have a returm for only one file telling me "object reference not set to an instance objet" => Ok, no prob. the srt file doesn't exist on addic7ed but then that's it, never another show showing up in alerts or what. Looking in logs i found : log extract.txt Seems it does multiple request in a short time and goes time out (site isn't very fluid, but shows up in less then 20sec ; maybe increasing a bit could help as we are just waiting for an answer ?), the plugin doesn't search anymore for a while as it timed out ; ok, why not. The problem i get it is :once timed out i'm some kind of IP Ban from addic7ed : manual search doesn't work anymore ; site is no more accessible from my server, but still ok in a virtual machine running on it besides a VPN, no prob' neither at home or if i put emby's server behind a VPN. Maybe 20 or 30minutes later, site is available again. I have the same "kind of IP Ban" if looking for multiples files in row manually It wasn't working with last stable, so i tried beta, same behaviour. Thanks PS : Settings , to be sure i unchecked those little things Waiting for instructions on expected files/informations needed Ty for investigations L. Hi, that's only addic7ed. The other two sources will still be fine in this situation.
JuJuJurassic 50 Posted January 29, 2022 Posted January 29, 2022 (edited) I'm having the same problem, I've just got open subtitles enabled and am a VIP member, I've attached the emby log file, I can see it contacting the open subtitle serer, but doesn't actually display anything. When playing a film, if I select a search for subtitles it always says not available. I don't mind taking another subscription out, is there a better solution? Thanks ----- Update, it seems to be okay after re entering the login credentials and rebooting the server. I hope this works for you too ---- embyserver (2).txt Edited January 29, 2022 by JuJuJurassic
Luke 42255 Posted January 31, 2022 Posted January 31, 2022 On 1/29/2022 at 12:18 PM, JuJuJurassic said: I'm having the same problem, I've just got open subtitles enabled and am a VIP member, I've attached the emby log file, I can see it contacting the open subtitle serer, but doesn't actually display anything. When playing a film, if I select a search for subtitles it always says not available. I don't mind taking another subscription out, is there a better solution? Thanks ----- Update, it seems to be okay after re entering the login credentials and rebooting the server. I hope this works for you too ---- embyserver (2).txtUnavailable Hi, are you all set now?
JuJuJurassic 50 Posted January 31, 2022 Posted January 31, 2022 Hi Luke, Perhaps I don't understand how it works. Is it dynamic so you start a film, then tell it to get subtitles, which it does, or in my case doesn't. or does it down load them to play later Any suggestions. Here's the emby log file look at the end for the subtitle search Julian embyserver (3).txt
Luke 42255 Posted January 31, 2022 Posted January 31, 2022 19 minutes ago, JuJuJurassic said: Hi Luke, Perhaps I don't understand how it works. Is it dynamic so you start a film, then tell it to get subtitles, which it does, or in my case doesn't. or does it down load them to play later Any suggestions. Here's the emby log file look at the end for the subtitle search Julian embyserver (3).txt 9.26 MB · 0 downloads What exactly happened when you tried to download subtitles during playback?
JuJuJurassic 50 Posted February 1, 2022 Posted February 1, 2022 The film plays, I select the CC box, and get the following. thanks
Luke 42255 Posted February 1, 2022 Posted February 1, 2022 1 minute ago, JuJuJurassic said: The film plays, I select the CC box, and get the following. thanks Have you taken a look at the bottom section of this guide? https://support.emby.media/support/solutions/articles/44001848856-manual-subtitle-downloads
Omahabrownie 9 Posted February 1, 2022 Posted February 1, 2022 I have tried all of this and it still will not work for me. I have just decided if I need and want a subtitle I will have to soften code it to the movie file.
Luke 42255 Posted February 2, 2022 Posted February 2, 2022 19 hours ago, Omahabrownie said: I have tried all of this and it still will not work for me. I have just decided if I need and want a subtitle I will have to soften code it to the movie file. @Omahabrownie what exactly did you try?
Omahabrownie 9 Posted February 2, 2022 Posted February 2, 2022 I have tried everything asked in this topic posting since I started it. When I do as your manual link above shows all i get is what JuJuJarasic showed above. Asking if I have configured it. I have configured it as shown but it does not work for me. I have even tried putting a subtile file in the same folder as the movie and it still does not see it.
Luke 42255 Posted February 2, 2022 Posted February 2, 2022 25 minutes ago, Omahabrownie said: I have even tried putting a subtile file in the same folder as the movie and it still does not see it. Hi, sure it will see it. Just make sure to name it appropiately: https://support.emby.media/support/solutions/articles/44001159160-subtitles and then run a library scan.
JuJuJurassic 50 Posted February 3, 2022 Posted February 3, 2022 OK, major embarrassment. I typo-ed my email address. I'm so sorry for the time you spent luke, it was fresh eyes that spotted it. Do you have a "buy me a coffee" link I can apologise for your wasted time? 1
JuJuJurassic 50 Posted February 3, 2022 Posted February 3, 2022 Mind you, is there a way of making subtitles download automatically when a new film is "put" in the library. How would you select the languages you wanted though. I'd like polish and Spanish subtitles to be downloaded automatically. or is this a feature request. BTW I still owe you a cup of coffee
GrimReaper 4912 Posted February 3, 2022 Posted February 3, 2022 (edited) 27 minutes ago, JuJuJurassic said: Mind you, is there a way of making subtitles download automatically when a new film is "put" in the library. How would you select the languages you wanted though. I'd like polish and Spanish subtitles to be downloaded automatically. Have you explored bottom of your Library options (you can also tick Show advanced settings for few extra options)? Edited February 3, 2022 by GrimReaper
JuJuJurassic 50 Posted February 3, 2022 Posted February 3, 2022 (edited) Excellent grim reaper, thank you. On the next release would it be possible to put a “test authentication” button to verify the login. It would stop muppets like me getting the credentials wrong. Edited February 3, 2022 by JuJuJurassic
Luke 42255 Posted February 4, 2022 Posted February 4, 2022 5 hours ago, JuJuJurassic said: Excellent grim reaper, thank you. On the next release would it be possible to put a “test authentication” button to verify the login. It would stop muppets like me getting the credentials wrong. Hi, yes this is a good idea. Thanks.
lethtel 0 Posted February 20, 2022 Posted February 20, 2022 On 1/13/2022 at 5:36 PM, Luke said: Hi, that's only addic7ed. The other two sources will still be fine in this situation. Hi Yeah, maybe but that doesn't solve the problem. If it's only available on addic7ed, it's done, no subtitles downloaded. So what now ? Grabbing subtitles from bazarr or subliminal until this get fixed.
Luke 42255 Posted February 21, 2022 Posted February 21, 2022 2 hours ago, lethtel said: Hi Yeah, maybe but that doesn't solve the problem. If it's only available on addic7ed, it's done, no subtitles downloaded. So what now ? Grabbing subtitles from bazarr or subliminal until this get fixed. It looks like addic7ed only allows a small number per day per ip address it seems.
Happy2Play 9814 Posted February 21, 2022 Posted February 21, 2022 16 minutes ago, Luke said: It looks like addic7ed only allows a small number per day per ip address it seems. Looks like Anonymous - You’re limited to 15 files / 24 hours Registered - Has an increased download limit to 40 subtitles / 24 hours VIP - Has an increased download limit to 80 subtitles / 24 hours, Quote G. How do I check my limits? Go to your “Panel“. You’’ find the limit in the information box there (Downloads today section). Clicking that will show you some detailed info about your last downloads.
lethtel 0 Posted February 23, 2022 Posted February 23, 2022 I wrote : Quote Seems it does [your plugin] multiple request in a short time and goes time out (site isn't very fluid, but shows up in less then 20sec ; maybe increasing a bit could help as we are just waiting for an answer ?), the plugin doesn't search anymore for a while as it timed out ; ok, why not. The problem i get it is : once timed out i'm some kind of IP Ban from addic7ed : manual search doesn't work anymore ; site is no more accessible from my server, but still ok in a virtual machine running on it besides a VPN, no prob' neither at home or if i put emby's server behind a VPN. Maybe 20 or 30minutes later, site is available again. I have the same "kind of IP Ban" if looking for multiples files in row manually I'm not even yet downloading something, just getting locked out of the site for searching on it without even getting one correct result. In attached files : Screenshot from emby with no results, screenshot from addic7ed with an existing result to be found by emby and screenshot from my todays limit.
Happy2Play 9814 Posted February 23, 2022 Posted February 23, 2022 @lethtel Can you post server log showing this import. Have you verified language is enabled in library subtitles settings. 2022-02-23 14:55:45.779 Debug App: Running FFProbeProvider for C:\Users\Media\Desktop\Videos\TV TESTING - 2\All American\Season 4\S04E07.strm 2022-02-23 14:55:45.780 Info HttpClient: GET https://www.addic7ed.com/ 2022-02-23 14:56:01.596 Info HttpClient: GET https://www.addic7ed.com/ajax_loadShow.php?show=6920&season=4 2022-02-23 14:56:06.871 Info HttpClient: GET https://www.addic7ed.com/updated/8/171589/4 2022-02-23 14:56:08.195 Info SubtitleManager: Saving subtitles to C:\Users\Media\Desktop\Videos\TV TESTING - 2\All American\Season 4\S04E07.fr.srt
