winniewangyh 2 Posted November 24, 2021 Posted November 24, 2021 I used 4.6.6.0, transcoding in this version is normal, but after upgrading to 4.6.7.0, I found that video transcoding could not be done, indicating that there is no compatible stream. The following is the log, please help to analyze the problem embyserver.txt ffmpeg-transcode-7b37aade-b6c9-4014-b31b-ad126f622f92_1.txt ffmpeg-transcode-70aa8c2a-c0ab-410e-969a-e94412198dd1_1.txt ffmpeg-transcode-63075c26-f3c9-4d8a-ac93-6566c8154c01_1.txt
Solution Luke 42243 Posted November 24, 2021 Solution Posted November 24, 2021 Hi, is this path valid? Notice the error messages: 12:50:16.544 /volume1/share/video/movie/比得兔2:逃跑计划 (2021)/比得兔2:逃跑计划 (2021) 2160p DTSHD-MA.mkv: No such file or directory 12:50:16.544
Happy2Play 9812 Posted November 25, 2021 Posted November 25, 2021 Yes you need to verify your library paths 2021-11-24 12:48:10.364 Info LibraryMonitor: Skipping realtime monitor for /volume1/share/video/7788/麻豆传媒 because the path does not exist 2021-11-24 12:48:10.364 Info LibraryMonitor: Skipping realtime monitor for /volume1/share/video/Adult Video because the path does not exist 2021-11-24 12:48:10.364 Info LibraryMonitor: Skipping realtime monitor for /volume1/share/video/movie because the path does not exist 2021-11-24 12:48:10.364 Info LibraryMonitor: Skipping realtime monitor for /volume1/share/video/TV because the path does not exist But since this is Synology a guess may be you did not add "emby" as System Internal User on each share.
Carlo 4561 Posted November 25, 2021 Posted November 25, 2021 @winniewangyh did either of these two posts help you solve your issue?
winniewangyh 2 Posted December 13, 2021 Author Posted December 13, 2021 On 2021/11/24 at PM10点48分, Luke said: 你好,这个路径有效吗?请注意错误消息: I am sorry that there is something wrong with my mailbox and I have not received any email notification. I have compared the path mapping and found that the path is indeed wrong. Thank you very much for reminding me
winniewangyh 2 Posted December 13, 2021 Author Posted December 13, 2021 On 2021/11/25 at AM11点02分, cayars said: @winniewangyh 这两个帖子中的任何一个是否帮助您解决了您的问题? Yes, thank you very much. 1
