hstamas 179 Posted January 13, 2022 Posted January 13, 2022 Just tried Button Mapper on my Sony and still have the problem.
Luke 42243 Posted January 13, 2022 Posted January 13, 2022 Are you using the remote in mouse mode where it puts a mouse pointer on the screen? Not that that should matter but just trying to reproduce.
pünktchen 1411 Posted January 13, 2022 Posted January 13, 2022 In my case no. If you want to reproduce it, buy a Flirc for 25$ on Amazon and return it after testing.
Luke 42243 Posted January 13, 2022 Posted January 13, 2022 9 minutes ago, pünktchen said: In my case no. If you want to reproduce it, buy a Flirc for 25$ on Amazon and return it after testing. Well the one I got I can't reproduce with so I'm going to try the exact one that was mentioned above.
Luke 42243 Posted January 16, 2022 Posted January 16, 2022 OK I have the GS30 and I can reproduce, so that's good. I'll work on getting this resolved as quickly as I can. Do you actually find this thing comfortable to use? The shape of it makes for an awkward feel in my opinion.
anhil 7 Posted January 16, 2022 Author Posted January 16, 2022 58 minutes ago, Luke said: OK I have the GS30 and I can reproduce, so that's good. I'll work on getting this resolved as quickly as I can. Do you actually find this thing comfortable to use? The shape of it makes for an awkward feel in my opinion. I do admit that the shape and button geometry of G30S leave a lot of room for improvement. If you now any alternatives in this process range ($10...$20) with similar features (RF air mouse with navigation buttons + learning IR remote + integrated mic for Google assistant), but with better ergonomics, please let me know
Luke 42243 Posted January 16, 2022 Posted January 16, 2022 This is the one I initially got because I figured I would get something that is used by more people: https://www.amazon.com/gp/product/B08VN98V93 And that remote is definitely much better than the G30, but the problem didn't occur with it so I couldn't use it for testing this issue.
anhil 7 Posted January 16, 2022 Author Posted January 16, 2022 (edited) 42 minutes ago, Luke said: This is the one I initially got because I figured I would get something that is used by more people: https://www.amazon.com/gp/product/B08VN98V93 And that remote is definitely much better than the G30, but the problem didn't occur with it so I couldn't use it for testing this issue. Thanks, that has much better ergonomics and button geometry with same features. I will check, what they ask for it in China... 1 h later: I checked the G20S remote (and the Pro variant and the Pro BT variant). Unfortunately in G20S (and in its variants) you can use the IR learn function only for the power key and for the mute key. Rest of the keys work only with RF/BT and cannot be taught any IR codes. Such a shame, since otherwise this would have been perfect. Edited January 16, 2022 by anhil Additions...
anhil 7 Posted January 16, 2022 Author Posted January 16, 2022 I ended up ordering this G40S (not from Amazon though), which is basically G30s with the awkward shape and button geometry corrected: https://www.amazon.com/Strqua-Gyroscope-Learning-Remote-Android/dp/B08L8ZGRLG 1
Luke 42243 Posted January 26, 2022 Posted January 26, 2022 Hi, can you please try this and let us know how it compares: Thanks.
anhil 7 Posted January 26, 2022 Author Posted January 26, 2022 13 hours ago, Luke said: Hi, can you please try this and let us know how it compares: Thanks. I checked this v 3.2.36 and unfortunately it still multiplies the pressing of the navigation keys of my factory provided BT remote on my TCL 43C725 television. Similarly as with the previous versions, turning on the accessibility service of the Button Manager app removes the multiplication problem. I will next it it with my MECOOL KM6 Deluxe and report the results shortly.
anhil 7 Posted January 26, 2022 Author Posted January 26, 2022 and having tested the same with MECOOL with both the factory provide BT remote and with G30s, the results are the same i.e. the multiplication phenomenon is still there. As before, Button Mapper with its accessibility service does not help like it helped with TCL.
anhil 7 Posted February 9, 2022 Author Posted February 9, 2022 I can add some more results obtained with remotes not yet reported: TCL 43C725 running Google TV & Emby for Android 3.2.36 and Tikigogo T3M remote => no multiplication effect, not even with Button Mapper disabled (!) MECOOL KM6 Deluxe running Android TV 10 & Emby for Android 3.2.36 and Tikigogo TK3 remote => multiplication effect is still there
hstamas 179 Posted February 16, 2022 Posted February 16, 2022 Had the chance to try this on my bedroom TLC 40". Latest Android beta with Button Mapper on and off. Not working in either case. Its not as bad as on my Sony TV but I still get consistent double jumps at the very least.
Spaceboy 2573 Posted February 16, 2022 Posted February 16, 2022 came across this while briefly testing the standard android app on my shield combined with a harmony remote and hub. the app was completely unusable 1
Luke 42243 Posted February 17, 2022 Posted February 17, 2022 Yes I'll take another look at this soon. Thanks guys.
Luke 42243 Posted July 28, 2022 Posted July 28, 2022 @anhil Can you please let me know if this is resolved in the latest version? https://emby.media/emby-for-android.html Thanks !
pünktchen 1411 Posted July 28, 2022 Posted July 28, 2022 Finally! No more unwanted keypress multiplication here. One little exception: keyboard "Escape" always reacts with exactly two actions. It doesn't happen with the "Backspace" button, but now also with a keyboard where i never encountered any problem before. 1
Luke 42243 Posted July 29, 2022 Posted July 29, 2022 48 minutes ago, pünktchen said: Finally! No more unwanted keypress multiplication here. One little exception: keyboard "Escape" always reacts with exactly two actions. It doesn't happen with the "Backspace" button, but now also with a keyboard where i never encountered any problem before. Thanks for the feedback. We'll take a look at escape.
anhil 7 Posted August 1, 2022 Author Posted August 1, 2022 On 29/07/2022 at 02:54, pünktchen said: Finally! No more unwanted keypress multiplication here. One little exception: keyboard "Escape" always reacts with exactly two actions. It doesn't happen with the "Backspace" button, but now also with a keyboard where i never encountered any problem before. Yes, I can confirm the same with my TCL 43C725 television: I no longer need to use Button Mapper to avoid multiplication effect. I have not yet tested with my MECOOL KM6 Deluxe, which was the tougher one, since using Button Mapper did not remove the multiplication effect. I will keep you posted. 1
Trevor68 70 Posted August 1, 2022 Posted August 1, 2022 Though this new version has removed the keyboard for CCwGTV remote.
