Lonald 10 Posted November 20, 2021 Posted November 20, 2021 I use Apple TV for playback and have both the A1842 and the A2169 models. Both are on the current OS and are running Emby 1.5.5 and I am using Windows server 4.6.6 on a PC with Windows 11. I have movies with both 1080p and 4k versions and use the following structure on my NAS: The Matrix (1999) [tmdbid=603] The Matrix (1999) [tmdbid=603] [4k].mkv The Matrix (1999) [tmdbid=603] [Blu-Ray].mkv When I call up the movie, the app only shows the 4k version as an option. For the Lord of the Rings The Fellow ship of the Rings, where each of the versions has two parts, only an unlabeled 1080p version is identified. These movies display and play properly on PCs. Thanks!
Lonald 10 Posted November 23, 2021 Author Posted November 23, 2021 Upgraded the Apple TV Emby App to 1.5.7 (1) and the lack of versions persists. The PC version and the Android versions both show and access the versions properly. Thanks!
Luke 42241 Posted November 29, 2021 Posted November 29, 2021 Quote the app only shows the 4k version as an option. Hi, where exactly are you referring to?
Funkshoi 0 Posted December 4, 2021 Posted December 4, 2021 I'm having the same issue with an apple tv A1625 [emby for tvOS 1.5.7] On the movie summary screen (where you can choose resume, play, trailers, etc) you cannot select between multiple versions like 1080 or 4K. The dropdown menu that exists on the browser version is not present on tvOS. Additionally, on this non-4K apple tv emby defaults to playing and transcoding the 4K version instead of the 1080p version which exists. It would make more sense for it to just play the 1080 one. A 1080p device should not default to a 4K version of any video if a 1080p version exists. Thanks
vdatanet 1619 Posted December 5, 2021 Posted December 5, 2021 Use the button Select audio and subtitles on the detail screen. There you can select the version. 1
Luke 42241 Posted December 5, 2021 Posted December 5, 2021 1 hour ago, vdatanet said: Use the button Select audio and subtitles on the detail screen. There you can select the version. Yes we need to get it directly onto the detail screen like our other apps, but until that time, it's still accessible under that button. 1 1
Lonald 10 Posted December 7, 2021 Author Posted December 7, 2021 Awesome. It works perfectly. Thank you!!!
