gcorgnet 5 Posted November 18, 2021 Posted November 18, 2021 (edited) Hi, I have configured an optional path in my libraries (eg \\server\folder) which should grant access to guests for read only. What's the best way of making sure the paths works correctly and is being used by apps on my network? I tried the logs but couldn't find anything conclusive. Thanks Edited November 18, 2021 by gcorgnet
GrimReaper 4861 Posted November 18, 2021 Posted November 18, 2021 1 minute ago, gcorgnet said: I have configured an optional path in my libraries (eg \\server\folder) which should grant access to guests for read only. What do you mean by that? You don't control access that way, you do it through User setting, either by folder-based access, PG or tags. As is where you grant or revoke any Admin privileges for the users.
rbjtech 5335 Posted November 18, 2021 Posted November 18, 2021 5 minutes ago, gcorgnet said: Hi, I have configured an optional path in my libraries (eg \\server\folder) which should grant access to guests for read only. What's the best way of making sure the paths works correctly and is being used by apps on my network? I tried the logs but couldn't find anything conclusive. Thanks Only certain clients will use the optional path - namely the Shield (if setup to do so) or the Windows Theatre Clients. There are two ways to verify - one is to look for the stream type to be FILE in stats for nerds, the other is to simply look on the host server OS and see if the file is being directly accessed. 1
