danpol 12 Posted November 21, 2021 Author Posted November 21, 2021 (edited) Appended screenshot. Edited November 21, 2021 by GrimReaper Mask remote IP
GrimReaper 4894 Posted November 21, 2021 Posted November 21, 2021 (edited) Those all appear correct, as nothing obvious stands out, I've pinged @cayars for remote session support once he finds the time. Edited November 21, 2021 by GrimReaper Typo
danpol 12 Posted November 21, 2021 Author Posted November 21, 2021 cannot connect from outside my home network tried to connect using mobile data on my phone just won't connect it sees the shield server but get error connection failure
GrimReaper 4894 Posted November 21, 2021 Posted November 21, 2021 (edited) 11 minutes ago, danpol said: it sees the shield server That would imply your remote connection is likely working, but you cannot login - which would mean a different issue, and different approach, by proxy. Does your user have Remote access enabled in User settings? Edit: have you tried connecting directly to remote IP, not using Connect? Edited November 21, 2021 by GrimReaper Afterthough
danpol 12 Posted November 21, 2021 Author Posted November 21, 2021 allow remote connections to this server is ticked
GrimReaper 4894 Posted November 21, 2021 Posted November 21, 2021 Just now, danpol said: allow remote connections to this server is ticked There's also a per-user setting, go to Users tab, edit any user, there's a checkbox for "Allow remote connections to this Emby server".
danpol 12 Posted November 21, 2021 Author Posted November 21, 2021 I have just setup Emby about a week ago so I have not added users until I myself can connect remotely and my user profile has "allow remote connections to this Emby server" ticked 1
Carlo 4561 Posted November 21, 2021 Posted November 21, 2021 I sent you a PM @danpol for remote assitance.
Luke 42238 Posted November 21, 2021 Posted November 21, 2021 1 hour ago, danpol said: how do I do that Did you receive his PM?
danpol 12 Posted December 6, 2021 Author Posted December 6, 2021 Update on this problem still not working cayars done a remote connection but unfortunately no joy @cayars
Happy2Play 9811 Posted December 7, 2021 Posted December 7, 2021 12 hours ago, danpol said: Update on this problem still not working cayars done a remote connection but unfortunately no joy This suggests something is preventing the connection on open port as it the connection is being reset.
Happy2Play 9811 Posted December 7, 2021 Posted December 7, 2021 11 hours ago, evermore said: I can't connect either.. I state that I have already tried to detach and reattach server and connection ... Unfortunately even if before it connected without problems .. Now It Gives Me Error What steps have you taken? https://support.emby.media/support/solutions/articles/44001849007-connectivity#:~:text=your home network.-,External Connections,-Emby Server also
Carlo 4561 Posted December 8, 2021 Posted December 8, 2021 On 12/6/2021 at 8:18 AM, danpol said: Update on this problem still not working cayars done a remote connection but unfortunately no joy @cayars I apologize, as I don't remember exactly what you're issue was, but if we didn't solve it, that would almost surely be a CGNAT situation from your ISP (but we can work around that) or more likely a couple of routers inline (NAT) and we didn't have the password available to make an adjustment to the first router. Do either of those sound familiar? If not, I'd be happy to take another quick look to see what the issue was. If you know how, you can open a command prompt and type from your PC tracert 8.8.8.8 That will show us each step a packet takes on the way out of our network. If there are two routers inline they will usually show up doing that. Same with an ISP CGNAT. If you send it to me via PM I can take which is probably better than posting it in the forum as it may contain your external IP. The other thing you can tell us that will normally rule out CGNAT situations is if the IP address shown on the Dashboard for remote matches the IP you see at canyouseeme.org. So are they the same IP or different? Thanks
danpol 12 Posted December 8, 2021 Author Posted December 8, 2021 hi yes that's me I'm the one with the Mac just checked canyouseeme and the IP address
Luke 42238 Posted December 14, 2021 Posted December 14, 2021 @danpol are you still having an issue with this?
danpol 12 Posted December 14, 2021 Author Posted December 14, 2021 yes still cannot connect outside of network
Carlo 4561 Posted December 22, 2021 Posted December 22, 2021 That's strange. If can you see me shows 8096 as open that would seem to indicate it's working. But If I wasn't able to help you previously that tells me this is far more involved. Do you by any chance have two routers in line? Perhaps and ISP mode/router and then your own? Or a router and an WIFI access connect to it? From your server if you drop to a command line and type tracert 8.8.8.8 what do you get? For Mac it might be traceroute vs tracert. You should see the first set of numbers (your lan) of numbers as 192, 10 or 172. Paste the results of this right up to the point the next entry does not start with any of those 3 numbers as that will be your public IP info. Or just PM me the full result. Depend on what we find we may be able to fix this if it's dual routers but you'll need to be able to log into both devices. If that is not the problem we may have to use a different solution. That solution depends on your need. If you want remote access just for yourself or family members the solution is simple (install ZeroTier or TailScale) as a private VPN solution so only you have access to your devices. If you need remote access for extended family or friends it's a much more complex issue to solve correctly with a relay server which typically will cost a few bucks a month.
Calmac83 0 Posted February 18, 2022 Posted February 18, 2022 On 08/12/2021 at 09:19, cayars said: I apologize, as I don't remember exactly what you're issue was, but if we didn't solve it, that would almost surely be a CGNAT situation from your ISP (but we can work around that) or more likely a couple of routers inline (NAT) and we didn't have the password available to make an adjustment to the first router. Do either of those sound familiar? If not, I'd be happy to take another quick look to see what the issue was. If you know how, you can open a command prompt and type from your PC tracert 8.8.8.8 That will show us each step a packet takes on the way out of our network. If there are two routers inline they will usually show up doing that. Same with an ISP CGNAT. If you send it to me via PM I can take which is probably better than posting it in the forum as it may contain your external IP. The other thing you can tell us that will normally rule out CGNAT situations is if the IP address shown on the Dashboard for remote matches the IP you see at canyouseeme.org. So are they the same IP or different? Thanks Hi, I live in a rural location and have to use a 4G router for my home internet. Because it is a mobile ISP that I am using, my WAN address is hidden behind CGNAT. You mention in the above, that you have a workaround for this. Please can you tell me what the workaround is so I can connect remotely to the server. Many Thanks.
