trusselo 225 Posted October 13, 2013 Posted October 13, 2013 I had mentioned this on the old forum but a couple updates later, and a few new box sets added, thought i should bring it back up. I created some box sets today, 'Bad Boys Collection' for example, Steps Taken: Create New folder 'Bad Boys Collection' Move Existing Movies 'Bad Boys' and 'Bad Boys II' into new collection folder. Create blank new file in collection folder called 'collection.xml' (sometimes server will automatically create folder.xml if you dont do this, and that causes the web interface to not let you add collection http link for themoviedb.org. different issue, type it up later.) Open web interface and edit collection, add collection link from themoviedb.org and SAVE Hit Refresh Meta info, description, images, all download, EXCEPT folder.jpg I have had to manually copy every folder.jpg from themoviedb.org for every collection recently.
Luke 42287 Posted October 13, 2013 Posted October 13, 2013 I'll test this out,but #3 is not true so you don't need to do that anymore. Actually - it's ok if you do that. You need to either do that or have [boxset] in the file name.
trusselo 225 Posted October 13, 2013 Author Posted October 13, 2013 AHHH!!!! did not know about [boxset] but ill keep to the xml. I did notice that the folder.xml issue is gone now. but ya still no folder.jpg
Abobader 3491 Posted October 13, 2013 Posted October 13, 2013 Good day, When I was testing before boxset, I found out best to make the folder name: Bad Boys [boxset] Then MB3 will get everything fine for it and will fetch images if it found. My best
trusselo 225 Posted October 13, 2013 Author Posted October 13, 2013 for me its finding all images, except folder.jpg...
Luke 42287 Posted October 13, 2013 Posted October 13, 2013 i tested using abo's method and had no issues.
trusselo 225 Posted October 13, 2013 Author Posted October 13, 2013 yup... worked without interaction at all... didnt have to edit the collection and add the link either. Damn... thats ugly.... 'The X-Files Collection [boxset]'
trusselo 225 Posted October 13, 2013 Author Posted October 13, 2013 so why is manual refreshing not downloading folder.jpg??
Solution Luke 42287 Posted October 13, 2013 Solution Posted October 13, 2013 there may be some issue with plugin interaction. try your manual test with a new boxset again but first remove all plugins.
trusselo 225 Posted October 13, 2013 Author Posted October 13, 2013 nailed it. Removed plugins: Trakt Coverart Trailers Restart server Manually setup a collection, and BAM. Folder.jpg shows. hmm
Redshirt 1487 Posted October 17, 2013 Posted October 17, 2013 It's a pita, but can you continue to test adding back those plugins one at a time. I'd like to take trakt of the table. Or fix it if necessary.
trusselo 225 Posted October 18, 2013 Author Posted October 18, 2013 yeah give me a couple days to get to it.
