rooser11 8 Posted November 18, 2021 Posted November 18, 2021 Is there anyway I can quickly set a subtitles offset value? pressing on +-50ms button is tedious when I have to set at +-6500 for each episode of a TV series. A slider or a direct input of the desirable value would be great. Thank you. 1
Luke 42235 Posted December 10, 2021 Posted December 10, 2021 Hi, are you using a mouse and keyboard or remote control?
rooser11 8 Posted December 10, 2021 Author Posted December 10, 2021 3 minutes ago, Luke said: Hi, are you using a mouse and keyboard or remote control? keyboard and mouse/trackpad
Luke 42235 Posted December 10, 2021 Posted December 10, 2021 When the button has focus you should be able to hold down enter, right?
rooser11 8 Posted December 10, 2021 Author Posted December 10, 2021 2 minutes ago, Luke said: When the button has focus you should be able to hold down enter, right? that does not work reliably on mac. i dont see the button being focused. i was able to do this with -50 and then after reset, i tried with +50 but no matter what i do i cannot make the button focused again and so Enter did not register.
Luke 42235 Posted December 10, 2021 Posted December 10, 2021 OK we'll look at improvements to this. Thanks.
kevinnashuk 7 Posted November 15, 2023 Posted November 15, 2023 Agree with this one, on an episode I tried it, subtitles were 35 seconds behind the speech, that's 35000ms! A box to type in would be nice, perhaps choose units too 1
Luke 42235 Posted May 9, 2024 Posted May 9, 2024 Subtitle offset is being changed to a slider which should make it much easier now, and you still have the buttons to step up/down: 1 1
