FrostByte 5454 Posted November 18, 2021 Posted November 18, 2021 On the server under users profile settings disable transcoding for video which will force it to try to Direct Play 1
barnum 5 Posted November 19, 2021 Author Posted November 19, 2021 So last night, I made some test disable all transcoding options for my account (2 video options and 1 audio). All the movies play correctly. I'll make test on Monday on then generate the logs for different files. To generate the log, should I keep all the trancodings option disable ? 1
Luke 42245 Posted November 19, 2021 Posted November 19, 2021 No I would put those back on as it may cause problems with other videos. But thanks, that was helpful.
ebr 16337 Posted November 22, 2021 Posted November 22, 2021 Hi. Please test this with the latest beta of the app. Thanks.
barnum 5 Posted November 23, 2021 Author Posted November 23, 2021 OK I'l try this new version. I also upgrade the firmware of my TV 1
barnum 5 Posted November 23, 2021 Author Posted November 23, 2021 (edited) With this version of the client everything is OK on my TV, 4k files are play without transcoding Regards Edited November 23, 2021 by barnum 1 1
mangis 10 Posted November 30, 2021 Posted November 30, 2021 Heya Was running into the same issue with my TCL 75C725. I used that workaround with the transcoding and did the trick If I join the beta program in the Play Store will this grab the same version that provided the fix in this case or is the app store a little behind the manual installs. Thanks
ebr 16337 Posted November 30, 2021 Posted November 30, 2021 27 minutes ago, mangis said: If I join the beta program in the Play Store will this grab the same version that provided the fix in this case or is the app store a little behind the manual installs. The app store is always behind but it is up to date at this moment.
Jaw94 0 Posted December 20, 2021 Posted December 20, 2021 Hi All, Im glad im not the only one that has had this issue, i have been putting it off, until my content started to grow in 4k... I have a TCL 75P725 , it looks like emby doesn't see that it has HDR or 4k..?? What would be the best option? Beta? Thank You
ebr 16337 Posted December 20, 2021 Posted December 20, 2021 3 hours ago, Jaw94 said: What would be the best option? Beta? Hi. For a fix right now, yes. We hope to release the current beta within the next few weeks.
