reptarsrage 0 Posted November 16, 2021 Posted November 16, 2021 (edited) Emby Version: 4.6.4.0 Playback Devices: Windows 11 Chrome, LG Smart TV, iOS App When playing certain content, the player will render frames out of order resulting in very choppy playback (see attached video). This happens with a few different files. I've attached the media info for one such file. This issue occurs across all devices that I've tested on. However, when played in VLC the file does not have this issue. Stats for Nerds: Playback Info Player: Web Video Player Play method: DirectPlay Protocol: http Stream type: Video Video Info Video resolution: 1920x1080 Dropped frames: 0 Corrupted frames: 0 Original Media Info Container: mkv Bitrate: 2.5 Mbps Video codec: HEVC Main Video bitrate: 2.5 Mbps Video framerate: 23.976025 fps Audio codec: AC3 Audio bitrate: 384 kbps Audio channels: 6 Audio sample rate: 48000 Hz Any guidance here would be super helpful. 2021-11-15 17-23-29.mp4 embyserver.txt Community.S02E19.Critical.Film.Studies.1080p.BluRay.DD5.1.x265-POIASD.mkv.info.txt Edited November 16, 2021 by reptarsrage
Solution Happy2Play 9802 Posted November 16, 2021 Solution Posted November 16, 2021 From a browser standpoint this is a known issue as most browsers do not even support this format. (best alternative is Emby Theatre for Windows) https://emby.media/community/index.php?/topic/102877-question-about-browser-support-for-hevc But the other client/apps would/should be a different issues. 1
reptarsrage 0 Posted November 16, 2021 Author Posted November 16, 2021 thanks for pointing me to that other topic, that's the exact issue I'm seeing!
