fraenhawk 61 Posted September 10, 2014 Posted September 10, 2014 (Running 3.0.5366.22005) There are a few ways to get into this situation with the top menu, but this is the most straightforward example. If you go into the web client on the home screen, scroll down to latest media and click on a show that you only have one new episode of, you go to the episode's page (with the hyperlinks for series and season). Look at the menu at the top. It's the one with Home, Latest, Next Up, Favorites, Upcoming. In other words the Home menu, not the Shows menu. The choices work on it. No problem. Now click the hyperlink for the series or season. The menu up top switches to the "TV" menu (Suggested, Latest, Upcoming, Shows, Episodes, Genres, People, Networks). Click on Suggested and it takes you back to the "Home" menu on "Next Up"?! If you go through all that and get back to the "TV" menu, most of the other options work and keep you in "TV mode". It only seems to be the Suggested and Upcoming that swap menus on you. If instead you just go through the TV views from the start, all the buttons leave you in "TV mode." So it all depends on how you got there.
Deathsquirrel 745 Posted September 10, 2014 Posted September 10, 2014 You can get the same result just clicking a movie in the latest media section on the Home page as well. Just tested that. It takes you to that movie's detail screen and the tabs at the top are Home | Latest | Next Up | Favorites | Upcoming.
