arrbee99 1836 Posted March 14, 2024 Posted March 14, 2024 Any news ? hopefully ? pleasey ? wistfully ?
norrox 2 Posted April 3, 2024 Posted April 3, 2024 On 3/14/2024 at 4:33 AM, arrbee99 said: Any news ? hopefully ? pleasey ? wistfully ? You can disregard this theme, op has posted the same stuff 2015, 2017 and 2021, now its 2024 and almost 10 years for a theme. if he's not dead. then this is just something he post to get attention every now and then. @Lukeprob should lock this thread. 1 1 1
Locutus64 125 Posted April 3, 2024 Posted April 3, 2024 8 hours ago, norrox said: You can disregard this theme, op has posted the same stuff 2015, 2017 and 2021, now its 2024 and almost 10 years for a theme. if he's not dead. then this is just something he post to get attention every now and then. @Lukeprob should lock this thread. My vote would be to remove the thread. 1
yardameus 221 Posted April 7, 2024 Posted April 7, 2024 If you'd used his themes before, you wouldn't be so quick to be negative. 1 1
Locutus64 125 Posted April 7, 2024 Posted April 7, 2024 4 hours ago, yardameus said: If you'd used his themes before, you wouldn't be so quick to be negative. Put down the crack pipe cause the Drano you've been smoking in it has really affected your brain. No one has tried this theme cause it's never been posted.
rbjtech 5341 Posted April 8, 2024 Posted April 8, 2024 On 07/04/2024 at 09:33, Locutus64 said: Put down the crack pipe cause the Drano you've been smoking in it has really affected your brain. No one has tried this theme cause it's never been posted. Wrong - I had an early demo of the app and it worked well - unfortunately, cheese has not been active on these forums for a year or so. I hope he is well, but life is always far more important than emby. 6
yardameus 221 Posted April 20, 2024 Posted April 20, 2024 On 4/7/2024 at 3:33 AM, Locutus64 said: Put down the crack pipe cause the Drano you've been smoking in it has really affected your brain. No one has tried this theme cause it's never been posted. I said used his themes before, MediaBrowser themes. Not this theme, but because of what he's done before I'm willing to be optimistic this will get done and be awesome. And don't trash my Drano, it's quality stuff.
Locutus64 125 Posted April 21, 2024 Posted April 21, 2024 (edited) Thanks for correcting your comment, that said optimism only goes sooooooo far. Edited April 21, 2024 by Locutus64 1
