V@l123 3 Posted February 3, 2022 Author Posted February 3, 2022 is there any special carracters that need to be avoid in password ? or \
Luke 42288 Posted February 4, 2022 Posted February 4, 2022 8 hours ago, V@l123 said: is there any special carracters that need to be avoid in password ? or \ Not that I'm aware of, no.
V@l123 3 Posted February 20, 2022 Author Posted February 20, 2022 I tried to re install emby server but the problem is still the same
Luke 42288 Posted March 2, 2022 Posted March 2, 2022 On 2/20/2022 at 5:51 AM, V@l123 said: I tried to re install emby server but the problem is still the same Hi, did you try changing your open subtitle password and then updating that in emby server?
Luke 42288 Posted March 22, 2022 Posted March 22, 2022 On 3/3/2022 at 12:45 PM, V@l123 said: yes multiple time Where exactly did you change your password?
V@l123 3 Posted March 30, 2022 Author Posted March 30, 2022 First on opensubtitle website and then in emby in the section regarding opensubitle
Luke 42288 Posted March 31, 2022 Posted March 31, 2022 17 hours ago, V@l123 said: First on opensubtitle website and then in emby in the section regarding opensubitle What open subtitle website exactly? What is the address?
V@l123 3 Posted April 1, 2022 Author Posted April 1, 2022 the address if opensubtitle website is https://www.opensubtitles.org/ Do you need something else ?
rbjtech 5345 Posted April 1, 2022 Posted April 1, 2022 This is a really odd one - so you can login to opensubtitles.org (NOT the same username/password as opensubtitles.com btw). Are you using the same server/workstation as Emby is running on to do the browser login/check - ie, it is the same source IP address ? I would reset the password again to something silly like 'emby1234' and then ensure you TYPE that into the Emby configuration (don't cut and paste), save and then try again. There is no issue here for other users, myself included - so it has to be either your account/password with opensubtitles.org OR emby itself cannot reach api.opensubtitles.org for some reason.
V@l123 3 Posted April 1, 2022 Author Posted April 1, 2022 8 hours ago, rbjtech said: This is a really odd one - so you can login to opensubtitles.org (NOT the same username/password as opensubtitles.com btw). yes and i also import my account on opensubtitle.com 8 hours ago, rbjtech said: Are you using the same server/workstation as Emby is running on to do the browser login/check - ie, it is the same source IP address ? I would reset the password again to something silly like 'emby1234' and then ensure you TYPE that into the Emby configuration (don't cut and paste), save and then try again. The request come from the same ip address (and i can see in the log that the API use .org address) I reset my password and type it in emby the result is still the same (not working ) but the error log is a little bit different (see attachement) 8 hours ago, rbjtech said: log_opensub_01042022.txt
BillOatman 597 Posted April 2, 2022 Posted April 2, 2022 Doesn't look like a config issue. Quote System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure. This in theory should fix it. Probably can add it right in the plugin code itself. ServicePointManager.ServerCertificateValidationCallback += (o, c, ch, er) => true;
Happy2Play 9814 Posted April 2, 2022 Posted April 2, 2022 I guess the real question is why OP's system is throwing the error? Have you modified the system cipher suites as this looks like system error to me. System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure. But have verified they do allow weak ciphers. A test from my Windows 11. But get same results testing on Windows 10. 2022-04-01 19:30:21.470 Info HttpClient: POST https://api.opensubtitles.org/xml-rpc 2022-04-01 19:30:21.930 Info SubtitleManager: Saving subtitles to C:\Users\Media\Desktop\Videos\Movies BIF Test\JT LeRoy (2019)\JT LeRoy (2019).en.srt 2022-04-01 19:30:24.869 Info HttpClient: POST https://api.opensubtitles.org/xml-rpc 2022-04-01 19:30:25.358 Info SubtitleManager: Saving subtitles to C:\Users\Media\Desktop\Videos\Movies BIF Test\The Clovehitch Killer (2018)\The Clovehitch Killer (2018).en.srt
V@l123 3 Posted April 2, 2022 Author Posted April 2, 2022 No i didn't change the cipher suite (or i'm not aware off). How can I check the list? I found a power shell command but I'm not sure that what I need)
V@l123 3 Posted April 2, 2022 Author Posted April 2, 2022 6 hours ago, BillOatman said: This in theory should fix it. Probably can add it right in the plugin code itself. ServicePointManager.ServerCertificateValidationCallback += (o, c, ch, er) => true; How to edit the plugin to test it?
BillOatman 597 Posted April 2, 2022 Posted April 2, 2022 6 hours ago, V@l123 said: How to edit the plugin to test it? It doesn't seem to be open source. So generally speaking, you can't, The author (Emby developers I assume) would need to.
V@l123 3 Posted April 2, 2022 Author Posted April 2, 2022 14 minutes ago, Luke said: Are you running on windows 7? No on windows 10
Luke 42288 Posted April 2, 2022 Posted April 2, 2022 11 minutes ago, V@l123 said: No on windows 10 Is Windows fully up to date?
V@l123 3 Posted April 2, 2022 Author Posted April 2, 2022 51 minutes ago, Luke said: Windows fully up to date? I just checked and it's fully up to date
Q-Droid 1011 Posted April 2, 2022 Posted April 2, 2022 (edited) Can you try a few things from Windows PowerShell? Do these on the same machine running Emby server. In PowerShell wget and curl are aliases for iwr, they do the same thing so try: iwr https://api.opensubtitles.org/xml-rpc It also looks like curl.exe is now built-in to Windows 10? Not the same as the PS alias for iwr and it also works in the CMD window. So you can try: curl.exe -v https://api.opensubtitles.org/xml-rpc There should be more verbose output from the last command. Edited April 2, 2022 by Q-Droid 1
V@l123 3 Posted April 3, 2022 Author Posted April 3, 2022 15 hours ago, Q-Droid said: iwr https://api.opensubtitles.org/xml-rpc The result from PS iwr https://api.opensubtitles.org/xml-rpc iwr : The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel. At line:1 char:1 + iwr https://api.opensubtitles.org/xml-rpc + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-WebRequest], WebExc eption + FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeWebRequestCommand and from CMD 16 hours ago, Q-Droid said: curl.exe -v https://api.opensubtitles.org/xml-rpc >curl.exe -v https://api.opensubtitles.org/xml-rpc * Trying 92.240.234.122:443... * Connected to api.opensubtitles.org (92.240.234.122) port 443 (#0) * schannel: disabled automatic use of client certificate * schannel: ALPN, offering http/1.1 * schannel: next InitializeSecurityContext failed: CRYPT_E_REVOKED (0x80092010) - The certificate is revoked. * Closing connection 0 curl: (35) schannel: next InitializeSecurityContext failed: CRYPT_E_REVOKED (0x80092010) - The certificate is revoked.
Q-Droid 1011 Posted April 3, 2022 Posted April 3, 2022 This is a bit weird. Your name resolution is sending your connection to an IP (92.240.234.122) that has an expired cert: Issuer: C=BE, O=GlobalSign nv-sa, CN=AlphaSSL CA - SHA256 - G2 Validity Not Before: Feb 24 06:06:06 2020 GMT Not After : Feb 24 06:06:06 2022 GMT Subject: OU=Domain Control Validated, CN=*.opensubtitles.org Even though the current DNS should resolve to Cloudflare: Non-authoritative answer: Name: opensubtitles.org Address: 172.64.131.37 Name: opensubtitles.org Address: 172.64.130.37 Name: opensubtitles.org Address: 2606:4700:e2::ac40:8325 Name: opensubtitles.org Address: 2606:4700:e2::ac40:8225 Do you have a hard coded hosts entry for opensubtitles on your machine that resolves to the old IP? ping api.opensubtitles.org nslookup api.opensubtitles.org 1
ebr 16354 Posted April 3, 2022 Posted April 3, 2022 I remember seeing a post recently that if your certificate is one of the Let's Encrypt ones with an expired certificate, you cannot connect to opensubtitles.org...
V@l123 3 Posted April 3, 2022 Author Posted April 3, 2022 7 hours ago, Q-Droid said: Do you have a hard coded hosts entry for opensubtitles on your machine that resolves to the old IP? ping api.opensubtitles.org nslookup api.opensubtitles.org No i don't have hard coded host entry here is the result of ping and snlookup ping api.opensubtitles.org Pinging api.opensubtitles.org [92.240.234.122] with 32 bytes of data: Reply from 92.240.234.122: bytes=32 time=45ms TTL=117 Reply from 92.240.234.122: bytes=32 time=41ms TTL=117 Reply from 92.240.234.122: bytes=32 time=42ms TTL=117 Reply from 92.240.234.122: bytes=32 time=41ms TTL=117 Ping statistics for 92.240.234.122: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 41ms, Maximum = 45ms, Average = 42ms C:\Users\Val_multi> C:\Users\Val_multi>nslookup api.opensubtitles.org Server: lan.home Address: 192.168.1.1 Non-authoritative answer: Name: api.opensubtitles.org Addresses: 2606:4700:3032::6815:164b 2606:4700:3032::ac43:cb72 172.67.203.114 104.21.22.75
