Vicpa 612 Posted September 10, 2014 Posted September 10, 2014 Hi, Since 2.1.0.115 I can't seem to play anything that is audio only. Music (which has always worked) is not working and the TuneIn plugin, both crash the app. TuneIn has not worked from a playlist for some time, but you could drill down to a station and it would play, this doesn't seem to be working either. I am sure is minor glitch somewhere, maybe on my end? Here is the log (both app and fatal)Win8Audio.txt Thanks as always for your help !
7illusions 1249 Posted September 10, 2014 Posted September 10, 2014 I'm looking into it right now, it's a problem with one of the mediabrowser nuget-packages.. @@Luke StreamBuilder.BuildAudioItem returns null, do you wan't to look into or shall I do it?
7illusions 1249 Posted September 10, 2014 Posted September 10, 2014 Luke,nevermind looking, I found the issue and will submit a PR shortly @@Vicpa , It will be fixed in a matter of days
7illusions 1249 Posted September 11, 2014 Posted September 11, 2014 @@Vicpa New version out, v2.1.1, that adresses your issue. Can you confirm that your issue is resolved? Thanks
Solution Vicpa 612 Posted September 11, 2014 Author Solution Posted September 11, 2014 Hi, Works great thanks!! 1
