ng4ever 40 Posted November 10, 2021 Posted November 10, 2021 (edited) I can't figure it out still. Thanks. This is on the iOS Emby app. Unless there is some third party app like Tautulli for plex that works. I doubt it. Thanks for any help. If this is the wrong forum sorry Yes Emby server is running on NAS. Edited November 10, 2021 by ng4ever
ng4ever 40 Posted November 10, 2021 Author Posted November 10, 2021 Just now, GrimReaper said: Is this split from another topic? Yes but I can't find the other topic
GrimReaper 4897 Posted November 10, 2021 Posted November 10, 2021 Then I suppose you're gonna have to give some more context, as I can't figure out what exactly you're trying to achieve.
ng4ever 40 Posted November 10, 2021 Author Posted November 10, 2021 Just now, GrimReaper said: Then I suppose you're gonna have to give some more context, as I can't figure out what exactly you're trying to achieve. Sure I am trying to get a notification on my iPhone from my Emby server when someone simply plays any media content.
GrimReaper 4897 Posted November 10, 2021 Posted November 10, 2021 You have several notification plugins to do that; seeing you're on iOS, you might go with Prowl, but also Pushbullet, Pushover, Telegram or whatever. Check Plugin Catalogue. 2
ng4ever 40 Posted November 10, 2021 Author Posted November 10, 2021 5 hours ago, GrimReaper said: You have several notification plugins to do that; seeing you're on iOS, you might go with Prowl, but also Pushbullet, Pushover, Telegram or whatever. Check Plugin Catalogue. I know but I need help setting it up please?
GrimReaper 4897 Posted November 10, 2021 Posted November 10, 2021 5 minutes ago, ng4ever said: I know but I need help setting it up please? I was using both Pushover and Pushbullet at some points in the past, haven't for some time, though, went next-level with webhooks and notifiarr, but sure, let's try to sort you out, what do you need help with? 1
ng4ever 40 Posted November 10, 2021 Author Posted November 10, 2021 1 minute ago, GrimReaper said: I was using both Pushover and Pushbullet at some points in the past, haven't for some time, though, went next-level with webhooks and notifiarr, but sure, let's try to sort you out, what do you need help with? Thanks first I need to know which plug in is best to use for me ? I know all have differences but I can't decide. I guess whatever is easiest and works best.
GrimReaper 4897 Posted November 10, 2021 Posted November 10, 2021 (edited) 5 minutes ago, ng4ever said: Thanks first I need to know which plug in is best to use for me ? I know all have differences but I can't decide. I guess whatever is easiest and works best. There's screenshots of both Pushbullet and Pushover above, which one you fancy more? They both work bassically same, not any notable differences there. For some eye-candy, notifiarr+discord. Edited November 10, 2021 by GrimReaper 1
ng4ever 40 Posted November 10, 2021 Author Posted November 10, 2021 1 minute ago, GrimReaper said: There's screenshots of both Pushbullet and Pushover above, which one you fancy more? They both work bassically same, not any notable differences there. For some eye-candy, notifiarr+discord. Pushover I guess sense I think Pushbullet costs money. Either way Pushover.
ng4ever 40 Posted November 10, 2021 Author Posted November 10, 2021 Sorry forgot to add what is next if I choose Pushover please?
GrimReaper 4897 Posted November 10, 2021 Posted November 10, 2021 7 minutes ago, ng4ever said: Sorry forgot to add what is next if I choose Pushover please? Install app on your phone. Head over to pushover.net to register app, as you'll need auth token. Download plugin from Catalogue, enter that token and user key. In Dashboard>Advanced>Notifications, configure events you want to be notified of. If you want daily summaries (Users watched/Media added) , install Playback Reporting Plugin. 1 1
ng4ever 40 Posted November 10, 2021 Author Posted November 10, 2021 1 minute ago, GrimReaper said: Install app on your phone. Head over to pushover.net to register app, as you'll need auth token. Download plugin from Catalogue, enter that token and user key. In Dashboard>Advanced>Notifications, configure events you want to be notified of. If you want daily summaries (Users watched/Media added) , install Playback Reporting Plugin. Thank you I will let you know if it works.
ng4ever 40 Posted November 10, 2021 Author Posted November 10, 2021 Just wish Emby had it built in oh well with the app.
GrimReaper 4897 Posted November 10, 2021 Posted November 10, 2021 Just now, ng4ever said: Just wish Emby had it built in oh well with the app. Well, all those notification events are built in, hence plugins, as we all have different preferences, you find out which one works best for your usage-case. 1 1
Carlo 4561 Posted November 11, 2021 Posted November 11, 2021 Yep, for example I don't want any type of notification for my system as it would be going off constantly so having them as plugins makes sense. This way I never load something I won't use. If everything was built directly in the main server it would use more memory and resources. For those using notification do you want 4 or 5 different things built in or just the one you use? Having things modular make sense as you only load things you want to use. The Emby plugins run in the same code or memory space as your server so they aren't 2nd class citizens or "plugins" in the traditional sense like on some other systems. With Emby architecture it's more like you pick the sets of things you want to load and run together which is quite nice. 1
ng4ever 40 Posted November 11, 2021 Author Posted November 11, 2021 1 minute ago, cayars said: Yep, for example I don't want any type of notification for my system as it would be going off constantly so having them as plugins makes sense. This way I never load something I won't use. If everything was built directly in the main server it would use more memory and resources. For those using notification do you want 4 or 5 different things built in or just the one you use? Having things modular make sense as you only load things you want to use. The Emby plugins run in the same code or memory space as your server so they aren't 2nd class citizens or "plugins" in the traditional sense like on some other systems. With Emby architecture it's more like you pick the sets of things you want to load and run together which is quite nice. Good point! 1
