softworkz 5133 Posted November 10, 2021 Posted November 10, 2021 51 minutes ago, BirdBare said: Oh I searched the text. It applied. Still only 1 transcode so far Sorry, I looked at the wrong log. Did this change the memory usage in any way? No need to do two transcodes, let's just check whether it changed mem usage at all. Also check the idle mem usage for comparison.
BirdBare 9 Posted November 10, 2021 Author Posted November 10, 2021 1 minute ago, softworkz said: Sorry, I looked at the wrong log. Did this change the memory usage in any way? No need to do two transcodes, let's just check whether it changed mem usage at all. Also check the idle mem usage for comparison. It did not change the mem usage at all according to nvidia-smi
softworkz 5133 Posted November 10, 2021 Posted November 10, 2021 (edited) TEST 3 For another try, you could change the "Transcoding Threads" setting under "Transcoding" to 1 (it comes at a different position and affects the decoder rather than the encoder) What's the idle ram usage? Edited November 10, 2021 by softworkz
softworkz 5133 Posted November 10, 2021 Posted November 10, 2021 (edited) TEST 4 I got one more: Go to "Transcoding" Select "Advanced" at the top Save Go to "Advanced Transcoding" Navigate to the NVENC H.264 Encoder and click the gear button: Now play with these two options: Don't bother trying two transcodes. Just try different combinations of these options and watch the effect on mem usage. Edited November 10, 2021 by softworkz
softworkz 5133 Posted November 10, 2021 Posted November 10, 2021 TEST 5 And another one: First go to "Transcoding" (where you've selected "Advanced" already) Under HEVC decoders, disable NVDEC and enable the CUVID one Save Make a test whether playback is working and see whether there's a change in mem usage (maybe not, the important change comes next) Then, under "Diagnostic Options", you'll see two find-replace text boxes for modifying ffmpeg commands: Search: -c:v:0 hevc_cuvid Replace: -c:v:0 hevc_cuvid -resize:v:0 1920x1080 Try playback and check mem usage
softworkz 5133 Posted November 17, 2021 Posted November 17, 2021 @BirdBare - Did you have a chance to try these things?
BirdBare 9 Posted November 23, 2021 Author Posted November 23, 2021 Hello! Sorry for the delay. So I went through each setting and had the following observation: 3: No change. The idle ram usage is zero because the GPU is used only for Emby. 4: This one was interesting. I was able to reduce and increase the ram usage with different settings. Unfortunately it was a change of about 50MB so not enough to get another 4k transcode working. 5: I did not see a change with this setting either. I decided to get a p2200 instead. I found one only for 200 dollars so I hit the jackpot. I do appreciate all the help. Unfortunately 4K transcodes use way more ram than I expected.
softworkz 5133 Posted November 23, 2021 Posted November 23, 2021 @BirdBare - thanks for trying. I had expected a bigger effect. Will investigate this in a while.
