GrimReaper 4897 Posted November 9, 2021 Posted November 9, 2021 Since it appears that only @cayars read this thread completely, I'll summarize it here for any future input: 1) Initial log, AVC Hi10p playback, naturally no HW acceleration on either VAAPI or QS, decoding in software only 2) BDMV playback, HW decoders not listed at all, decoding in software only 3) Plain AVC 8-bit playback, HW mode:Yes, VAAPI decoder, Processing Plan correct, errs on playback, log saturated with decoder errors 4) Plain AVC 8-bit playback, HW mode: Advanced, QS decoder, Processing Plan correct, errs on playback, log saturated with decoder errors Next step: awaiting Carlo to test actual media file, which OP shared together with hardware detection log.
softworkz 5133 Posted November 10, 2021 Posted November 10, 2021 (edited) Could you please try the following to change the VAAPI driver: install the Diagnostics Plugin from the Catalog Reboot Make the settings as indicated below Reboot Retry with VAAPI Edited November 10, 2021 by softworkz
Carlo 4561 Posted November 10, 2021 Posted November 10, 2021 8 hours ago, GrimReaper said: Next step: awaiting Carlo to test actual media file, which OP shared together with hardware detection log. Having a bit of trouble downloading the file. Downloading now at a steady 2Mb. Waiting to see how the changes softworkz mentioned work out as well. 1
softworkz 5133 Posted November 10, 2021 Posted November 10, 2021 It wasn't always same file - was it? @Sailence - Have you had any videos with which VAAPI is working?
Sailence 0 Posted November 10, 2021 Author Posted November 10, 2021 16 minutes ago, softworkz said: It wasn't always same file - was it? @Sailence - Have you had any videos with which VAAPI is working? 2 hours ago, softworkz said: Could you please try the following to change the VAAPI driver: install the Diagnostics Plugin from the Catalog Reboot Make the settings as indicated below Reboot Retry with VAAPI I try that,it can't play also. Playback Error No compatible streams are currently available. Please try again later or contact your system administrator for details. ffmpeg-transcode-8c953f23-ad30-42ea-aaaa-157cd6ea7340_1.txt
Sailence 0 Posted November 10, 2021 Author Posted November 10, 2021 32 minutes ago, softworkz said: It wasn't always same file - was it? @Sailence - Have you had any videos with which VAAPI is working? I tried to play other files in my video library, and the hardware decoding never work,include H264,H265,HEVC,8bit,4K,1080P,720P.
softworkz 5133 Posted November 10, 2021 Posted November 10, 2021 It looks like a driver issue. Please try the steps above for changing the driver. Thanks.
softworkz 5133 Posted November 10, 2021 Posted November 10, 2021 Sorry, it seems you already did that. Could you please post the hw detection log?
Sailence 0 Posted November 10, 2021 Author Posted November 10, 2021 3 minutes ago, softworkz said: 抱歉,您似乎已经这样做了。 你能把硬件检测日志贴出来吗? hw detection log for i965. hardware_detection-63772142205_i965.txt
softworkz 5133 Posted November 10, 2021 Posted November 10, 2021 OK thanks, this looks good. In your recent ffmpeg log - did you have hw acceleration disabled? Please go to "Transcoding" and change to "Yes" (not Advanced, you can change back to Advanced later)
Sailence 0 Posted November 10, 2021 Author Posted November 10, 2021 2 小时前,softworkz 说: 好的,谢谢,这看起来不错。 在您最近的 ffmpeg 日志中 - 您是否禁用了硬件加速? 请转到“转码”并更改为“是” (不是高级,以后可以改回高级) I try i965+advanced and i965+yes,it can't play also. ffmpeg-transcode-25ace6dc-1070-439d-87b8-c47a9614747f_i965&advanced.txt ffmpeg-transcode-493bdede-2792-4e23-ab6e-ae15cb3f97cf_i965&yes.txt
softworkz 5133 Posted November 10, 2021 Posted November 10, 2021 That's weird. When it doesn't work with both drivers there must be some issue at the side of the hardware or OS configuration. It is possible to connect a monitor to the box?
Sailence 0 Posted November 10, 2021 Author Posted November 10, 2021 38 minutes ago, softworkz said: 这很奇怪。 当它不适用于两个驱动程序时,硬件或操作系统配置方面一定存在一些问题。 可以将显示器连接到盒子吗? I can connect a monitor to the xpenology. Is this what you need?
softworkz 5133 Posted November 10, 2021 Posted November 10, 2021 1 minute ago, Sailence said: I can connect a monitor to the xpenology. Is this what you need? Yes, please try this: Connect a monitor Restart the xpenology Check whether the monitor works Check whether transcoding works Thanks
Sailence 0 Posted November 10, 2021 Author Posted November 10, 2021 59 minutes ago, softworkz said: 是的,请试试这个: 连接显示器 重启xpenology 检查显示器是否工作 检查转码是否有效 谢谢 I connect a monitor to the xpenology, then reboot the xpenology, please see the picture for the information displayed. Then enter the xpenology, the display has no information, the indicator light of the display is green. Following is the interface of BIOS.
softworkz 5133 Posted November 10, 2021 Posted November 10, 2021 Sorry, I just realized that xpenology is a hack for running Synology software on any computer. I'm not familiar with this and can't provide much help here. The only other reason I can think of is that maybe the kernel is too old or something else is wrong with that OS image. 1
Solution Carlo 4561 Posted November 10, 2021 Solution Posted November 10, 2021 (edited) I too did not realize this was xpenology as the title says DS918+ which it isn't. 918+ is a reference to the actual hardware, not the software running on which would likely be DSM 6 or DSM 7 these days. Xpenology is neither as it does hardware emulation and includes a patched (not true) version of an older DSM release. Generally speaking xpenology will work ok for normal things that don't care about hardware but may have issues with actual hardware interaction as it's not really present. As an interesting test I created a VM on my actual Synology 920+ and installed xpenology in it. I was not able to get hardware transcoding to work this way either and that's on actual Synology hardware. I did not spend a lot of time on this so I'm not saying it can't be done, but it would probably require a lot of tinkering with at the OS level and isn't something Emby can directly support. Here is the actual file downloaded playing on my actual Synology. Work with VAAPI or QUICKSYNC. Edited November 10, 2021 by softworkz Bolded solution text 1 1
softworkz 5133 Posted November 10, 2021 Posted November 10, 2021 1 hour ago, cayars said: I too did not realize this was xpenology as the title says DS918+ which it isn't. I updated the title to reflect this. 1
