AntaresFR 9 Posted November 8, 2021 Posted November 8, 2021 I, i think there is a little problem with /Items/{Id}/Similar Endpoint. If I want only TVShows to be retrieven from the call, I put IncludeItemTypes=Series on the query but it returns Movie items too. Regards
murxer83 17 Posted November 8, 2021 Posted November 8, 2021 Hello, I do it like that only Series: params = {"fields": "ParentId,Overview,ProductionYear,SortName,Genres,Studios,People,Runtime,OfficialRating,CommunityRating,ProductionLocations", "startIndex": startIndex, "limit": limit } url = '{url}/Shows/{Id}/Similar'.format(url=self.connector.url, Id=Id) url = /Show/Id/Similar and only Movies: params = {"fields": "ParentId,Overview,ProductionYear,SortName,Genres,Studios,People,Runtime,OfficialRating,CommunityRating,ProductionLocations", "startIndex": startIndex, "limit": limit } url = '{url}/Movies/{Id}/Similar'.format(url=self.connector.url, Id=Id) url = /Movies/Id/Similar greetings murxer
AntaresFR 9 Posted November 8, 2021 Author Posted November 8, 2021 (edited) Hi, thank you for the reply; I tried with {url}/Shows/{Id}/Similar But same result as /Items/{Id}/Similar?IncludeItemTypes=Series I think one is an alias of the other. Edited November 8, 2021 by AntaresFR
murxer83 17 Posted November 8, 2021 Posted November 8, 2021 and if you include that in the params ExcludeItemTypes="Movie". Since I am currently working on a plugin myself, I have already noticed that some parameters have no effect.
AntaresFR 9 Posted November 8, 2021 Author Posted November 8, 2021 3 minutes ago, murxer83 said: and if you include that in the params ExcludeItemTypes="Movie". Since I am currently working on a plugin myself, I have already noticed that some parameters have no effect. Same, I think the parameter doesn't work cause i can put anything in IncludeItemTypes and nothing change. ExcludeItemTypes does nothing too.
murxer83 17 Posted November 8, 2021 Posted November 8, 2021 yes, exactly like that, I feel the same way. Maybe someone will contact you as to why this is the case.
AntaresFR 9 Posted November 8, 2021 Author Posted November 8, 2021 Yes. I could refilter another time the json result to remove movie things but it's a little dirty
Luke 42237 Posted November 8, 2021 Posted November 8, 2021 Those params might not be implemented with the similar endpoint. We'll take a look. Thanks. 1
murxer83 17 Posted November 8, 2021 Posted November 8, 2021 In the Swagger Ui the following is written at similar http://my_server_ip:8096/swagger "/Items/{Id}/Similar": { "get": { "tags": [ "LibraryService" ], "summary": "Gets similar items", "description": "Requires authentication as user", "externalDocs": { "description": "API Documentation: Item Information", "url": "https://github.com/MediaBrowser/Emby/wiki/Item-Information" }, "operationId": "getItemsByIdSimilar", "produces": [ "application/json", "application/xml" ], "parameters": [ { "in": "path", "name": "Id", "description": "Item Id", "required": true, "type": "string" }, { "in": "query", "name": "IncludeItemTypes", "description": "Optional. If specified, results will be filtered based on item type. This allows multiple, comma delimeted.", "type": "string", "collectionFormat": "multi" }, { "in": "query", "name": "EnableImages", "description": "Optional, include image information in output", "type": "boolean" }, { "in": "query", "name": "EnableUserData", "description": "Optional, include user data", "type": "boolean" }, { "in": "query", "name": "ImageTypeLimit", "description": "Optional, the max number of images to return, per image type", "type": "integer", "format": "int32" }, { "in": "query", "name": "EnableImageTypes", "description": "Optional. The image types to include in the output.", "type": "string" }, { "in": "query", "name": "UserId", "description": "Optional. Filter by user id, and attach user data", "type": "string", "format": "guid" }, { "in": "query", "name": "Limit", "description": "Optional. The maximum number of records to return", "type": "integer", "format": "int32" }, { "in": "query", "name": "Fields", "description": "Optional. Specify additional fields of information to return in the output. This allows multiple, comma delimeted. Options: Budget, Chapters, DateCreated, Genres, HomePageUrl, IndexOptions, MediaStreams, Overview, ParentId, Path, People, ProviderIds, PrimaryImageAspectRatio, Revenue, SortName, Studios, Taglines, TrailerUrls", "type": "string", "collectionFormat": "multi" } ], "responses": { "200": { "description": "Operation successful. Returning a QueryResult<BaseItemDto> object.", "schema": { "$ref": "#/definitions/QueryResult_BaseItemDto" } }, "400": { "$ref": "#/responses/400" }, "401": { "$ref": "#/responses/401" }, "403": { "$ref": "#/responses/403" }, "404": { "$ref": "#/responses/404" }, "5XX": { "$ref": "#/responses/5XX" } }, "security": [ { "apikeyauth": [ ] }, { "embyauth": [ ] } ], "x-RequiredAuthentication": "Requires authentication as user" should actually work { "in": "query", "name": "IncludeItemTypes", "description": "Optional. If specified, results will be filtered based on item type. This allows multiple, comma delimeted.", "type": "string", "collectionFormat": "multi" }
AntaresFR 9 Posted November 8, 2021 Author Posted November 8, 2021 It should, but it doesn't That's why i posted !
ebr 16332 Posted November 8, 2021 Posted November 8, 2021 Hi. The documentation may be incorrect at this point. Since no Emby apps filter those lists in any way, those parameters have never been used and so may not be implemented at this time.
AntaresFR 9 Posted November 8, 2021 Author Posted November 8, 2021 Nice, So could it be possible to implement them ?
Luke 42237 Posted November 11, 2021 Posted November 11, 2021 Yes it's something we can look at. Thanks.
