Combine m3u audio and video streams
Hi Luke,
Trying to add NASA TV to Emby. I cannot make it work as the audio and video streams are separate....
Any way to make this work?
This is what I've tried adding to the m3u file (it will play the video, but no audio):
#EXTINF:-1 channel-id="2750" tvg-logo="https://i.imgur.com/VX4uHSO.png" group-title="USA",NASA TV
#EXT-X-MEDIA:LANGUAGE="en-US",AUTOSELECT=YES,TYPE=AUDIO,URI="http://a93e545a-lp-omega.ums.services.video.ibm.com/playlist/directhls/channel/6540154/3/playlist.m3u8?authType=IP_BASED_IDENTITY&appType=12&appVersion=1&segmentType=ts&content=audiovideo&sgn=88e32db87f437ad699cb7d3ed560d4d28d33cc52&cdnHost=uhs-akamai.ustream.tv/",GROUP-ID="audiogroup",DEFAULT=YES,NAME="English (US)"
#EXT-X-MEDIA:LANGUAGE="en-US",AUTOSELECT=YES,TYPE=AUDIO,URI="http://a93e545a-lp-omega.ums.services.video.ibm.com/playlist/directhls/channel/6540154/8/playlist.m3u8?authType=IP_BASED_IDENTITY&appType=12&appVersion=1&segmentType=ts&content=audiovideo&sgn=293f4a30535f1ce529cafaeee484e2ca8f60339e&cdnHost=uhs-akamai.ustream.tv/",GROUP-ID="audiogroup",DEFAULT=YES,NAME="English (US)"
#EXT-X-MEDIA:LANGUAGE="mis-00",AUTOSELECT=NO,FORCED=NO,TYPE=SUBTITLES,URI="http://a93e545a-lp-omega.ums.services.video.ibm.com/playlist/directhls/channel/6540154/9/playlist.m3u8?authType=IP_BASED_IDENTITY&appType=12&appVersion=1&segmentType=ts&sgn=b6145507fe8a5f35b7c68b52fd9b1aee020c3f0d&cdnHost=uhs-akamai.ustream.tv/",GROUP-ID="subs",DEFAULT=NO,NAME="Unknown language"
#EXT-X-ALLOW-CACHE:NO
#EXT-X-STREAM-INF:CODECS="mp4a.40.2,avc1.77.31",RESOLUTION=1280x720,SUBTITLES="subs",BANDWIDTH=2849792,AUDIO="audiogroup",CLOSED-CAPTIONS=NONE
http://a92ccb54-lp-omega.ums.services.video.ibm.com/playlist/directhls/channel/6540154/2/playlist.m3u8?authType=IP_BASED_IDENTITY&appType=12&appVersion=1&segmentType=ts&content=audiovideo&sgn=c24a2d4ff965b2ea7a189c91d27d57e7297dcbb9&cdnHost=uhs-akamai.ustream.tv/
Thanks as always
I'll PM you an alternate stream you can use.
