Spacefred 0 Posted November 6, 2021 Posted November 6, 2021 when playing a video on my nvidia shield with TrueHD 96Khz, I get audio drops every 10-15 seconds. My receiver correctly shows that it is getting the TruHD stream at 96Khz. I have the same issue with Plex (VLC is working perfectly). Is this a known issue? Is emby using exoplayer and it's where the issue lies? Thanks
Luke 42245 Posted November 6, 2021 Posted November 6, 2021 Quote Is emby using exoplayer Hi, on android yes we are.
Luke 42245 Posted November 9, 2021 Posted November 9, 2021 Hi, please follow the discussion here: Thanks.
Spacefred 0 Posted November 9, 2021 Author Posted November 9, 2021 I checked it out but my issue is limited to 96Khz - the issue mentioned there has to do with 48Hz and high bandwidth. for me every 96Khz title fails regardless of total bandwidth. Exoplayer had an issue with 96khz DTS-HD that was fixed a few months ago so I'm thinking it;'s in the same line. VLC works without issue.
FrostByte 5454 Posted November 9, 2021 Posted November 9, 2021 6 minutes ago, Spacefred said: I checked it out but my issue is limited to 96Khz - the issue mentioned there has to do with 48Hz and high bandwidth. for me every 96Khz title fails regardless of total bandwidth. Exoplayer had an issue with 96khz DTS-HD that was fixed a few months ago so I'm thinking it;'s in the same line. VLC works without issue. Do you know which version of Exoplayer that was fixed in? ExoPlayer/RELEASENOTES.md at release-v2 · google/ExoPlayer · GitHub
Spacefred 0 Posted November 9, 2021 Author Posted November 9, 2021 (edited) Plex android TV 8.12.0 fixed it - they mention updating ExoPlayer to r2.12.1 in the release notes of the Beta 4 days before another Beta lists the fix. I don't know if that's the one but hopefully it narrows it down. Edited November 9, 2021 by Spacefred
ebr 16337 Posted November 9, 2021 Posted November 9, 2021 4 hours ago, Spacefred said: ExoPlayer to r2.12.1 We are well beyond that release of Exo so that isn't the solution.
Spacefred 0 Posted November 9, 2021 Author Posted November 9, 2021 This was the solution for DTS-HD - this thread is for TrueHD
FrostByte 5454 Posted November 9, 2021 Posted November 9, 2021 Did you see this ticket? Play Dolby threehd 96hz sample rate(bitstreaming).The voice was intermittent · Issue #419 · Nevcairiel/LAVFilters · GitHub It looks like at the bottom there was a commit on Sep 11 which I assume made it into version 2.15.1 then? If you follow the code Properly account for the number of samples in every TrueHD audio fram… …e when bitstreaming Resolves an issue with A/V sync and possible audio skipping when bitstreaming TrueHD
Spacefred 0 Posted November 9, 2021 Author Posted November 9, 2021 I did not - interesting - what's the exoplayer version used by the current emby Android TV?
FrostByte 5454 Posted November 9, 2021 Posted November 9, 2021 2 minutes ago, Spacefred said: I did not - interesting - what's the exoplayer version used by the current emby Android TV? Right now latest beta has 2.13.2. If you open the server log and search for "Exoplayer" it will display the version on that line I'm looking at the Exoplayer release notes though and I can't make out if the commit actually made it into the releases, or not
ebr 16337 Posted November 15, 2021 Posted November 15, 2021 On 11/9/2021 at 5:58 PM, FrostByte said: Did you see this ticket? Play Dolby threehd 96hz sample rate(bitstreaming).The voice was intermittent · Issue #419 · Nevcairiel/LAVFilters · GitHub It looks like at the bottom there was a commit on Sep 11 which I assume made it into version 2.15.1 then? If you follow the code Properly account for the number of samples in every TrueHD audio fram… …e when bitstreaming Resolves an issue with A/V sync and possible audio skipping when bitstreaming TrueHD I just looked at this more closely. That code change is in LAVFilters, not Exoplayer... 1
FrostByte 5454 Posted November 15, 2021 Posted November 15, 2021 2 hours ago, ebr said: I just looked at this more closely. That code change is in LAVFilters, not Exoplayer... Ok, thanks. That's why I didn't see it mentioned in the release notes
Luke 42245 Posted November 16, 2021 Posted November 16, 2021 Are you still having an issue with this?
