Carlo 4561 Posted December 28, 2021 Posted December 28, 2021 I' received the m3u and xml file and looking into it. On Windows I have zero problems with the streams even playing back in Chrome. They are loading on Synology now to try streams a different way as well.
Carlo 4561 Posted December 28, 2021 Posted December 28, 2021 Just got done doing a remote session and we got him some guide data but his provider data is really bad. Many of his channels originate from the UK so we can use Emby Guide data for those channels. Problem is I keep getting frozen or disconnected as he has a severe bandwidth issue at the moment. Emby Server is on the other side of the living quarters connected via WIFI going through a repeater. A speedtest shows 250ms jitter, 2.5 Mb upload and 15 Mb download. <-- That's a good test. So he is going to try and get this fixed which will improve what we already fixed and then with some UK channel mapping using Emby Guide data should be in great shape.
Luke 42243 Posted December 29, 2021 Posted December 29, 2021 @YairYakov have your questions been answered?
YairYakov 1 Posted December 29, 2021 Author Posted December 29, 2021 Yes thank you so much for all the help 1
