vaise 340 Posted October 30, 2023 Posted October 30, 2023 Never seen that. Also the tunnel works via cgnat so changing IP’s should have no issue. My ip has changed many times. Never an issue. It’s also not called Argo for a while. Any change you are using an old config or something? Maybe watch the old ibracorp YouTube vid on setup to compare config/setup?
Flamez 0 Posted November 22, 2023 Posted November 22, 2023 (edited) Well, it finally happened to me. The free version of Cloudflare with emby it has stopped working. When attempting to start a video stream it just hangs and never plays the video. Oh well it was a good run while it lasted. Edited November 22, 2023 by Flamez
frrilay 0 Posted January 25, 2024 Posted January 25, 2024 (edited) Hi all, anyone got recently TOS'ed? I couldn't find section 2.8 on their website anymore. Maybe it has changed place. Edited January 25, 2024 by frrilay
vaise 340 Posted January 25, 2024 Posted January 25, 2024 1 hour ago, frrilay said: Hi all, anyone got recently TOS'ed? I couldn't find section 2.8 on their website anymore. Maybe it has changed place. Still waiting…..
darkassassin07 674 Posted January 25, 2024 Posted January 25, 2024 (edited) 2 hours ago, frrilay said: Hi all, anyone got recently TOS'ed? I couldn't find section 2.8 on their website anymore. Maybe it has changed place. https://blog.cloudflare.com/updated-tos/ Tldr; you can stream media as long as it's hosted on cloudflares systems. You cannot use the WAF (proxy) service to stream media from your own systems. It'll work for a bit, then you'll get throttled and things will start to buffer like mad. Happed to me about two years ago. Just switched the 'proxied' toggle off so cloudflare only performs dns. Been fine since. Edited January 25, 2024 by darkassassin07 1
JulesC 51 Posted February 2, 2024 Posted February 2, 2024 (edited) I recently switched from Google Domain where I was able to remotely access Emby to Cloudflare. I followed the "Recommended Cloudflare Settings provided by @pir8radio(THANK YOU!), however, now I'm unable to access Emby remotely which is hosted on my Synology NAS. I'm receiving the following error: "The page isn’t working. <domain_name> redirected you too many times." I used the video linked below to switch from Google Domains to Cloudflare and followed the Recommended Cloudflare Settings. I'm not a network expert, so here are my naive questions: When I transferred my domain from Google Domains to Cloudflare, it transferred over my DNS Settings (i.e. Type "A" and "CNAME"). Cloudflare recommends steps to complete zone set-up "Add an A, AAAA, or CNAME record for www so that <domain_name> will resolve" It currently has: Type "A", Name (required) "<domain_name>, IPv4 address (required) <my WAN address>, Proxy Status - Proxied, TTL - Auto * Should I make any edits here? "CNAME" _domainconnect connect.domains.google.com , Proxy Status - Proxied * I'm assuming I should delete this record - right? On my Synology NAS, I have the Reverse Proxy enabled - worked for Google Domains * Any changes I should consider? Do I have to change the Ports that I'm using on Emby for Local and WAN? UPDATE: On Emby Remote (WAN) Access, I was using Port 8920. According to Cloudflare, they do NOT support this Port. Anything else that I should try? Any and all guidance is appreciated so I can have my remote family accessing Emby again. THANK YOU Edited February 2, 2024 by JulesC
darkassassin07 674 Posted February 2, 2024 Posted February 2, 2024 (edited) Ports 80/443 are the only ones supported for connections proxied through cloudflare. Streaming media through cloudflares proxy is against their TOS however, and will be throttled eventually. Disable 'proxied status' under dns records so it says 'DNS only'. Then you can continue to use 8096/8920. Edited February 2, 2024 by darkassassin07 1
JulesC 51 Posted February 2, 2024 Posted February 2, 2024 5 minutes ago, darkassassin07 said: Ports 80/443 are the only ones supported for connections proxied through cloudflare. Streaming media through cloudflares proxy is against their TOS however, and will be throttled eventually. Disable 'proxied status' under dns records so it says 'DNS only'. Then you can continue to use 8096/8920. @darkassassin07Thank you so very much!!! That did the trick. Just for my own learning, should I leave "CNAME" _domainconnect connect.domains.google.com , Proxy Status - Proxied alone? I'm only asking because it points to google and I switched to cloudflare. Thanks again...
darkassassin07 674 Posted February 2, 2024 Posted February 2, 2024 You can remove it, it shouldn't be necessary.
JulesC 51 Posted February 2, 2024 Posted February 2, 2024 57 minutes ago, darkassassin07 said: You can remove it, it shouldn't be necessary. @darkassassin07Thanks! I removed it and all is well.
simonguillot@yahoo.ca 1 Posted February 3, 2024 Posted February 3, 2024 I need help to sort this out please guys I am at loss What is the best option? I heard cloudflare is no go. Now twingate? I desperately need help to acces my emby server and file server from outside Any tutorials? I'm freaking out right now TIA
Luke 42255 Posted February 3, 2024 Posted February 3, 2024 1 hour ago, simonguillot@yahoo.ca said: I need help to sort this out please guys I am at loss What is the best option? I heard cloudflare is no go. Now twingate? I desperately need help to acces my emby server and file server from outside Any tutorials? I'm freaking out right now TIA Re: Duplicate posting from:
crusher11 1150 Posted February 28, 2024 Posted February 28, 2024 I'm currently getting a 521 error when attempting to visit my domain.
Neminem 1626 Posted February 28, 2024 Posted February 28, 2024 Look at this Cloudflare Error 521: Learn 4 Methods to Fix this Problem (hostinger.com) It might help you.
crusher11 1150 Posted February 28, 2024 Posted February 28, 2024 I can't see how any of that applies to an Emby install, to be honest.
darkassassin07 674 Posted February 28, 2024 Posted February 28, 2024 Cloudflare can't reach your server. Do they have the right ip? Can you reach your server from your wan ip? (from outside your lan)
vaise 340 Posted February 28, 2024 Posted February 28, 2024 33 minutes ago, crusher11 said: I can't see how any of that applies to an Emby install, to be honest. Cloudflare has nothing to do with emby. It’s just a host machine it points to. Try turning off the cf button for your dns in cf console. See it it works with pure dns, then work backwards if that comms test works. i still use tunnels myself.
crusher11 1150 Posted February 28, 2024 Posted February 28, 2024 40 minutes ago, darkassassin07 said: Cloudflare can't reach your server. Do they have the right ip? Can you reach your server from your wan ip? (from outside your lan) IP is fine. It's been working for the past few years with no issue. Trying IP+port fails, but I'm pretty sure it's always failed due to the SSL setup anyway.
crusher11 1150 Posted February 28, 2024 Posted February 28, 2024 20 minutes ago, vaise said: Cloudflare has nothing to do with emby. It’s just a host machine it points to. Try turning off the cf button for your dns in cf console. See it it works with pure dns, then work backwards if that comms test works. i still use tunnels myself. You mean switch it from "proxied" to "DNS only"? That gets me an "unable to connect" error from my browser.
vaise 340 Posted February 28, 2024 Posted February 28, 2024 59 minutes ago, crusher11 said: You mean switch it from "proxied" to "DNS only"? That gets me an "unable to connect" error from my browser. Sounds like an issue on your back end server then. Assuming your wan ip address has not changed by your internet provider.
crusher11 1150 Posted February 28, 2024 Posted February 28, 2024 8 minutes ago, vaise said: Sounds like an issue on your back end server then. Assuming your wan ip address has not changed by your internet provider. Don't see why it would have. Googling "what is my IP" gives me the same address CF is set up with.
vaise 340 Posted February 28, 2024 Posted February 28, 2024 Good, wan ip is good. if the port being forwarded to your emby server would be next thing to check.
vaise 340 Posted February 28, 2024 Posted February 28, 2024 If port is forwarding to server, and dns proxy is off, you can use an open port checker from internet to emby server port. If it does not work, you have to fix that comms somehow. I used to have proxy on, 443 to reverse proxy, then to emby (before cf tunnels which I do now).
crusher11 1150 Posted February 28, 2024 Posted February 28, 2024 1 hour ago, vaise said: If port is forwarding to server, and dns proxy is off, you can use an open port checker from internet to emby server port. If it does not work, you have to fix that comms somehow. I used to have proxy on, 443 to reverse proxy, then to emby (before cf tunnels which I do now). Ports report closed. Router settings seem fine though.
