Phone Guy 0 Posted September 10, 2014 Posted September 10, 2014 Is it possible to switch the audio language track during playback of an mkv file from within mediabrowser? (example, more wife friendly) I know how to do it from the task tray, selecting the haali spliter or whichever audio icon it is (I forget), and selecting the language manually.... need something a little more spouse friendly even a way to cycle thru available audio tracks until you hit the right one would be ok.... of course, all capable during playback without exiting mediacenter/mediabrowser. Thanks.
ebr 16337 Posted September 10, 2014 Posted September 10, 2014 You have to define "within mediabrowser". I'm inferring from some of your other statements you mean inside MBC. If so, then no, not directly. There are some external things you can install (one is called media control) to allow you to do it but they require a certain codec setup and the interfaces are somewhat clunky (IMO). In just about every client other than MBC, yes, you can do this pretty easily.
