ebr 16337 Posted April 21, 2022 Posted April 21, 2022 38 minutes ago, crusher11 said: I forgot to note the time I sent the log. Same user as previously, GMT+8, somewhere between 23:43 and 23:45. Played Babel (MPEG2 BD), All About Eve (MPEG2 DVD), then S1E1 of The Alfred Hitchcock Hour (DVD-sourced but converted to H264 to remove PAL speedup). Dropped quality to 1Mbps to force transcode. Played Babel, All About Eve 2x, S1E1 AHH. Transcoding worked for All About Eve this time, the issue last time must have been a one-off glitch. It also rectified the diagonal green line issue. So we have something of a workaround, at least, it would seem. There is, however, a SfN issue as it insisted things were direct playing even when the OSD said they were transcoding during the latter test. Hi. He is asking for the ffmpeg logs, not the app logs... 47 minutes ago, crusher11 said: I just played All About Eve, and pulled up Stats for Nerds immediately, and it was direct playing for about five seconds then switched to Direct Stream. Weird. That is normal. It takes about 10 seconds for all the information to get updated from the server when not direct playing.
crusher11 1143 Posted April 21, 2022 Posted April 21, 2022 Just now, ebr said: Hi. He is asking for the ffmpeg logs, not the app logs... That is normal. It takes about 10 seconds for all the information to get updated from the server when not direct playing. I PM'd him server and ffmpeg logs. It definitely took way longer than ten seconds on one occasion.
crusher11 1143 Posted April 23, 2022 Posted April 23, 2022 @softworkz Have you had a chance to look at the latest set of logs?
softworkz 5133 Posted April 23, 2022 Posted April 23, 2022 On 4/21/2022 at 4:14 AM, softworkz said: I'm not familiar with the device itself, so I can't help with hands-on experience, but I can help with pinpointing strategies, and this is actually a good starting point: We got our failing case and We got something similar that works Let's compare these two cases. Just create a single ffmpeg log file for each case, then we can look at the differences. (I know you have sent many logs for the failing case already, but creating two logs directly one after another provides maximum differentiation from unexpected factors)
softworkz 5133 Posted April 23, 2022 Posted April 23, 2022 (edited) 1 hour ago, crusher11 said: Yes, I sent you those. I think there exists a communication problem. I'm not sure whether it is of visual nature or a language issue? On 4/21/2022 at 4:14 AM, softworkz said: I'm not familiar with the device itself, so I can't help with hands-on experience, but I can help with pinpointing strategies, and this is actually a good starting point: We got our failing case and We got something similar that works On 4/21/2022 at 4:14 AM, softworkz said: Let's compare these two cases. Just create a single ffmpeg log file for each case, then we can look at the differences. (I know you have sent many logs for the failing case already, but creating two logs directly one after another provides maximum differentiation from unexpected factors) Edited April 23, 2022 by softworkz
crusher11 1143 Posted April 23, 2022 Posted April 23, 2022 On 4/21/2022 at 11:48 PM, crusher11 said: I forgot to note the time I sent the log. Same user as previously, GMT+8, somewhere between 23:43 and 23:45. Played Babel (MPEG2 BD), All About Eve (MPEG2 DVD), then S1E1 of The Alfred Hitchcock Hour (DVD-sourced but converted to H264 to remove PAL speedup). Dropped quality to 1Mbps to force transcode. Played Babel, All About Eve 2x, S1E1 AHH. Transcoding worked for All About Eve this time, the issue last time must have been a one-off glitch. It also rectified the diagonal green line issue. So we have something of a workaround, at least, it would seem. There is, however, a SfN issue as it insisted things were direct playing even when the OSD said they were transcoding during the latter test. I sent logs for this. That's a success and a failure, back to back, with logs. As requested.
crusher11 1143 Posted April 26, 2022 Posted April 26, 2022 @softworkz I don't understand what you think the difference is between your request and the logs provided. Did you not get my last PM?
crusher11 1143 Posted April 28, 2022 Posted April 28, 2022 @softworkz I'd like to get this resolved so I can replace the All About Eve video with the one from the Blu-ray.
Luke 42245 Posted April 29, 2022 Posted April 29, 2022 Hi, please try side loading our standard Android app on the same device and let us know how that compares: https://emby.media/emby-for-android.html Thanks.
crusher11 1143 Posted May 8, 2022 Posted May 8, 2022 It plays successfully. So the green lines issue is specifically an ATV issue, it would seem.
Luke 42245 Posted May 8, 2022 Posted May 8, 2022 2 hours ago, crusher11 said: It plays successfully. So the green lines issue is specifically an ATV issue, it would seem. That's good news. Thanks for the feedback.
crusher11 1143 Posted May 9, 2022 Posted May 9, 2022 Doesn't really move us toward a solution in itself, however.
crusher11 1143 Posted May 9, 2022 Posted May 9, 2022 So with the new info are there any other logs that would be helpful? @ebr @softworkz
Luke 42245 Posted May 9, 2022 Posted May 9, 2022 1 hour ago, crusher11 said: So with the new info are there any other logs that would be helpful? @ebr @softworkz I don' t think there's anything more to do now that you've reported success with the standard app. The TV app will ultimately get the same updates to the video player.
emg456 3 Posted May 24, 2022 Posted May 24, 2022 On 09/05/2022 at 15:06, Luke said: I don' t think there's anything more to do now that you've reported success with the standard app. The TV app will ultimately get the same updates to the video player. So I just got round to side loading the Android app onto my Firetv stick and in my case the corruption is not fixed. I have tried both apps- standard Android 3.2.48 and Android TV 2.0.70g. Both show the corruption and in addition the standard Android app plays videos with a distorted aspect ratio- presumably designed for portrait use on a phone.
Luke 42245 Posted May 25, 2022 Posted May 25, 2022 16 hours ago, emg456 said: So I just got round to side loading the Android app onto my Firetv stick and in my case the corruption is not fixed. I have tried both apps- standard Android 3.2.48 and Android TV 2.0.70g. Both show the corruption and in addition the standard Android app plays videos with a distorted aspect ratio- presumably designed for portrait use on a phone. Hi, we'll take a look at it. Thanks.
emg456 3 Posted May 26, 2022 Posted May 26, 2022 Thanks. If you need logs and sample file I can organise that. 1
