any way to scan for missing images for recent added episodes?
horstepipe
Hello
for sure I am not the only one with that problem.
If you add a very recent episode which doesn't have a primary image added to any provider, there doesn't seem to be an automated way getting it some hours later except refreshing  the whole libary. Besides this is a demanding process, even that you can't trigger automatically.
So does anybody has a solution for that, maybe some scanning of recent added episodes via api?
Best regards
Edited by horstepipe
refresh, not scan
Hi, one possible way would be to look at recently added episodes which should make it clear what doesn't have proper images.
You could then multi-select them and fetch meta-data and replace images only on those items.
  • Thanks 1
horstepipe
Yeah thanks!
is that technically possible via api to do it automated?
so
- fetch last 5 added episodes
- replace images on tnem
horstepipe
Or even better
- fetch last added 5 episodes where primary image is missing
I'm not sure what would be involved but I'd image you could do something like this.
horstepipe
Okay I‘ll look into it, thanks!
Let us know how you get on. Thanks.
