justinrh 266 Posted November 3, 2021 Posted November 3, 2021 Guide data is wrong for W34EY-D 38.1, 35810. It is showing programs that aren't playing. Instead of Newsy shows, it looks like Court TV shows.
Carlo 4561 Posted November 3, 2021 Posted November 3, 2021 Hi, if you go into channel mapping on your system, what does the mapping look like for this channel?
justinrh 266 Posted November 3, 2021 Author Posted November 3, 2021 Is this what you are asking about?
Carlo 4561 Posted November 3, 2021 Posted November 3, 2021 Everything I see on line says this channel is CourtTV. Did it recently change in your area?
justinrh 266 Posted November 4, 2021 Author Posted November 4, 2021 I know Newsy.com has recently been advertising to rescan to get the channel (so that network is new to the area). I don't if it was Court TV before. Newsy.com says it should be airing on 38.8, which would require a scan.
Carlo 4561 Posted November 4, 2021 Posted November 4, 2021 Have you done a channel scan with your tuner? If you watch the channel is it showing Newsy? I'm happy to report this to our guide provider but just want to verify first the channel has actually changed.
Carlo 4561 Posted November 5, 2021 Posted November 5, 2021 It has been reported. Thanks @justinrh for verifying this for us. 1
justinrh 266 Posted March 6, 2022 Author Posted March 6, 2022 The programs listing is correct now, but the channel icon still shows Court TV.
Carlo 4561 Posted March 14, 2022 Posted March 14, 2022 On 3/6/2022 at 6:11 PM, justinrh said: The programs listing is correct now, but the channel icon still shows Court TV. Can you check this again and let us know if the proper icon is there now?
