thomsi 1 Posted October 31, 2021 Posted October 31, 2021 I have searched on here and the internet but cannot find a solution to my problem. I added Emby in Open Media Vault via a docker container. This is a copy of my docker-compose file --- version: "2.1" services: emby: image: lscr.io/linuxserver/emby container_name: emby environment: - PUID=998 - PGID=100 - TZ=Europe/London volumes: - /srv/dev-disk-by-uuid-99958201-12b5-4839-94b5-dc7fb1c3a81c/Config/Emby:/config - /srv/dev-disk-by-uuid-f9f4d5ff-ea6b-48df-b7f9-9ad0f22443b8/3DMovies:/data/3dmovies - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/4KMovies:/data/4kmovies - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/AMC:/data/amc - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/AP:/data/ap - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/AdultTVShows:/data/adulttvshows - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/AnimationMovies:/data/animationmovies - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/AudioBooks:/data/audiobooks - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/ChristmasCartoons:/data/christmascartoons - /srv/dev-disk-by-uuid-f9f4d5ff-ea6b-48df-b7f9-9ad0f22443b8/ChristmasMovies:/data/christmasmovies - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/ClassicKidsTV:/data/classickidstv - /srv/dev-disk-by-uuid-f9f4d5ff-ea6b-48df-b7f9-9ad0f22443b8/ComedyTVShows:/data/comedytvshows - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/Comics:/data/comics - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/CookingShows:/data/cookingshows - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/DiscoveryChannel:/data/discoverychannel - /srv/dev-disk-by-uuid-f9f4d5ff-ea6b-48df-b7f9-9ad0f22443b8/Disney:/data/disney - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/Documentaries:/data/documentaries - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/E-Books:/data/e-books - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/HomeMovies:/data/homemovies - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/Karaoke:/data/karaoke - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/Laurel&Hardy:/data/laurel&hardy - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/LiveConcerts:/data/liveconcerts - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/LooneyTunesCartoons:/data/looneytunescartoons - /srv/dev-disk-by-uuid-f9f4d5ff-ea6b-48df-b7f9-9ad0f22443b8/Movies:/data/movies - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/Movies2:/data/movies2 - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/Music:/data/music - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/MusicVideos:/data/musicvideos - /srv/dev-disk-by-uuid-f9f4d5ff-ea6b-48df-b7f9-9ad0f22443b8/Photos:/data/photos - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/TVDocumentaries:/data/tvdocumentaries - /srv/dev-disk-by-uuid-f9f4d5ff-ea6b-48df-b7f9-9ad0f22443b8/TVShows:/data/tvshows - /srv/dev-disk-by-uuid-2e1326e0-7e4d-4b90-bc34-a88b8bbf7142/TvShows2:/data/tvshows2 - /srv/dev-disk-by-uuid-8189a618-e12b-4035-9de5-fa919b03e027/Transcoding:/data/transcoding - /srv/dev-disk-by-uuid-6187b3b5-e4bb-4696-aa35-66396b8a33d4/Cache:/data/cache ports: - 8096:8096 restart: unless-stopped What I want to do is add a cartoon folder to Emby. How do I edit the file in a container already running. I am new to docker and portainer, any help will be much appreciated.
Solution Junglejim 385 Posted October 31, 2021 Solution Posted October 31, 2021 Hi mate, did you deploy it via a stack? if so head to portainer and select the emby stack, then select the editor tab and add your desired volume. After that select update stack under the actions menu on the editor tab below your compose file you just edited. If you ever want to update emby.. in portainer select the containers menu and select emby. You should see a recreate tab at the top, select that and make sure you toggle on "Pull latest image" and select recreate.
thomsi 1 Posted October 31, 2021 Author Posted October 31, 2021 (edited) 2 minutes ago, Junglejim said: Hi mate, did you deploy it via a stack? if so head to portainer and select the emby stack, then select the editor tab and add your desired volume. After that select update stack under the actions menu on the editor tab below your compose file you just edited. If you ever want to update emby.. in portainer select the containers menu and select emby. You should see a recreate tab at the top, select that and make sure you toggle on "Pull latest image" and select recreate. Hi mate yes I did, thanks for the reply, will have a look now. Many thanks edit, found it thanks, easy really, never notice the edit tab when i first looked. Edited October 31, 2021 by thomsi
