kbeck 64 Posted October 29, 2021 Posted October 29, 2021 I don't remember the exact option but I can't seem to find it. To display similar movies as a collection in the display. I have it set for one Library buy not another and now can't find it. Thanks.
GrimReaper 4861 Posted October 29, 2021 Posted October 29, 2021 Library settings>Import collection information (and set minimum number of items). Make sure TMDB scraper is enabled.
kbeck 64 Posted October 29, 2021 Author Posted October 29, 2021 4 minutes ago, GrimReaper said: Library settings>Import collection information (and set minimum number of items). Make sure TMDB scraper is enabled. Thanks but that's not what I'm looking for. I have the Collections. But there is another option to display the Collections in the Media View?? Home View?? Not sure what that view is called. Attached.
GrimReaper 4861 Posted October 29, 2021 Posted October 29, 2021 Just now, kbeck said: Thanks but that's not what I'm looking for. I have the Collections. But there is another option to display the Collections in the Media View?? Home View?? Not sure what that view is called. Attached. That tab should come automatically in any Movie-type library, you can't enable/disable that (as with any other tab), no Tabs row customization option yet.
MBSki 1115 Posted October 29, 2021 Posted October 29, 2021 Do you mean "group items into collections"? If so that would be in the view setting. In the web app you click the 3 dots to get the option. 2
ebr 16309 Posted October 29, 2021 Posted October 29, 2021 Hi. Click the "..." and select "Group items into collections".
GrimReaper 4861 Posted October 29, 2021 Posted October 29, 2021 Just now, mbarylski said: Do you mean "group items into collections"? If so that would be in the view setting. In the web app you click the 3 dots to get the option. Ahhh, I thought OP was referring to Collections tab. Nice one.
Solution Gilgamesh_48 1243 Posted October 29, 2021 Solution Posted October 29, 2021 6 minutes ago, kbeck said: Thanks but that's not what I'm looking for. I have the Collections. But there is another option to display the Collections in the Media View?? Home View?? Not sure what that view is called. Attached. Click on the three dots on the right side. The resulting menu includes "Group items into collections" and checking that will couse collections to display inline with your movies. Note: That means that any movies in collections will not be displayed normally in the regular view. Movies in collections only appear inside said collection.
kbeck 64 Posted October 29, 2021 Author Posted October 29, 2021 2 minutes ago, mbarylski said: Do you mean "group items into collections"? If so that would be in the view setting. In the web app you click the 3 dots to get the option. That's it, but which 3 dots?? They are 3 dots in the Libraries to get to Options....
kbeck 64 Posted October 29, 2021 Author Posted October 29, 2021 Got it . Thanks all. Missed the 3 dots on the View..... Happens often with me.
kbeck 64 Posted October 29, 2021 Author Posted October 29, 2021 11 minutes ago, mbarylski said: Do you mean "group items into collections"? If so that would be in the view setting. In the web app you click the 3 dots to get the option. Thanks. You understood what I was looking for and had the solution, but I couldn't find the 3 dots right away. More than 1 set of 3 dots and I kept looking at the one in the Libraries. 1
MBSki 1115 Posted October 29, 2021 Posted October 29, 2021 6 minutes ago, kbeck said: Thanks. You understood what I was looking for and had the solution, but I couldn't find the 3 dots right away. More than 1 set of 3 dots and I kept looking at the one in the Libraries. Glad you found it. Sometimes those settings can be tricky to find.
Gilgamesh_48 1243 Posted October 29, 2021 Posted October 29, 2021 18 minutes ago, mbarylski said: Glad you found it. Sometimes those settings can be tricky to find. Tricky??? I sometimes feel that settings get placed in nefarious ways just so the developers have things to laugh at. I believe this line happens in Emby conferences quite often: "OK, we have this feature available and working. Now, where do we hide it"?"
kbeck 64 Posted October 29, 2021 Author Posted October 29, 2021 Just now, Gilgamesh_48 said: Tricky??? I sometimes feel that settings get placed in nefarious ways just so the developers have things to laugh at. I believe this line happens in Emby conferences quite often: "OK, we have this feature available and working. Now, where do we hide it"?" I am with you on that one. Can't say how many times I have looked and looked for something I KNOW I had seen before.
