saifshaikh1721 0 Posted October 28, 2021 Posted October 28, 2021 Hello, I have installed Emby server on Ubuntu 20.04 LTS. Everything works fine if I download something manually (without sonarr) but if I download through sonarr, I get playback error - "No compatible streams are currently available. Please try again later or contact your system administrator for details." Please guide me on how to fix this. I have been stuck on this for hours. Regards, Saif
Luke 42246 Posted October 28, 2021 Posted October 28, 2021 Hi there, can we please look at an example? Thanks.
CassTG 113 Posted October 28, 2021 Posted October 28, 2021 (edited) 2 hours ago, saifshaikh1721 said: Hello, I have installed Emby server on Ubuntu 20.04 LTS. Everything works fine if I download something manually (without sonarr) but if I download through sonarr, I get playback error - "No compatible streams are currently available. Please try again later or contact your system administrator for details." Please guide me on how to fix this. I have been stuck on this for hours. Regards, Saif Is this via seperate Servers or Docker on the same server - If dockers this maybe something to look at: If you are using emby connect in *arr are the docker side paths in your compose file exactly the same as in your docker config for emby i.e *arr -v downloads:/mediapath/subfoldertv/ emby -v media:/mediapath/subfoldertv/ The first part before the colon is irrelevant (host path) but the path after (how its reached inside docker container) needs to match otherwise *arr will report an incorrect file path to Emby So if it was incorrect the following would happen *arr -v downloads:/mediapath/subfoldertv/ emby -v media:/mediapath/tv/ emby connect in *arr will tell emby the file is located at /mediapath/subfoldertv/ whereas emby is expecting files in /mediapath/tv/ which would throw the above error as the path doesent exist inside emby libraries That would correct itself however after a automated scan would run Edited October 28, 2021 by CassTG
